Results 1 to 8 of 8
Thread: Noob Question: Toyota 2TC vs 2TG
    Jul 2012
    Kentucky
    111
    I am still fairly new to classic Toyotas, so please bear with me if this has been addressed (several times?) before. I plan on desmogging the 2TC in my 74 SR5, after which I also plan to open it up a bit with a new intake and exhaust. I have been looking at dual side draft Webers as a future investment, which look to be ~ $1k. That said, I have seen some old listings for running 2TGs which run from ~$1k to ~$2.5k. Is this about right? It seems to me that a 2TG, though perhaps a bit more expensive than a new set of Webers and intake, is a much more worthy investment. Can anyone please shed some light on this? Is a good running 2TG a better performance value than buying new intake, exhaust, and ignition for the 2TC I currently have?
    Jul 2012
    Medford, OR
    16
    Re: Noob Question: Toyota 2TC vs 2TG
    The 2TG in theory would have better top end flow characteristics being a dual cam as opposed to a single cam but at the same time there is so much aftermarket support for the 2TC and so many circle track racers making 200hp N/A that I don't see the point in making the change.
    Jul 2012
    Kentucky
    111
    I sort of assumed that to be the case, but I didn't want to invest in the 2TC if the 2TG could be gotten as a better overall value.
    Sep 2010
    Magna, UT
    689
    My concern would be getting parts when needed since the TG was never a factory option here and they are ancient now, so even less readily available parts. Although it seems like people still get the parts.
    Jul 2012
    Medford, OR
    16
    By the time you spend $1500 bucks on a 2TG you will have about 20 more hp than a 2TC, instead you could spend that $1500 at BRD Racing and build a fire breathing 2TC, with lots of available parts and it would be bulletproof.
    Jul 2012
    Kentucky
    111
    I just found some prices on performance pieces for the 2TG...ouch. I am definitely sticking with the pushrod engine for a long time.
    May 2011
    Netherlands
    170
    Good choice. There are a lot of tuned 2T-C bulletproof engines running around now.
    Jan 2009
    Mauka
    66
    I would go with the 3TC.
  1. 22r-e into AE86. noob question
    By errolae92 in forum Toyota Garage
    Last Post: 06-15-2012, 03:32 PM
  2. Noob Question - Vehicle ID help
    By Drive510 in forum Off-Topic
    Last Post: 02-11-2012, 07:35 AM
  3. Question for you Toyota guys
    By RaptorReed in forum Toyota Garage
    Last Post: 04-17-2011, 11:02 AM
  4. suspension question from a noob.
    By pagong in forum Toyota Garage
    Last Post: 07-19-2009, 01:28 AM
  5. Toyota Engine Question
    Last Post: 06-22-2009, 06:08 AM
