Results 1 to 2 of 2
Thread: Diff ratio?
    May 2011
    Diff ratio?
    Friend of mine with a 2TG powered Corolla KE20 and T50 trans is at the moment on a diff shop for a new gear ratio.
    He uses now a 4.3 diff ratio and want to go to 3.9:1
    for his calculations see:
    Some further specs:
    red line 7000 revs
    Tire 205mm 60% 13 inch
    He now drives on 165/65/13 to 165km/h on 7500 revs in 5th gear ??
    Way too short
    Any comments from you on this matter from transmission specialists? :P
    May 2011
    Re: Diff ratio?
    He mounted a 3.3:1 diff and locked it, 100% LSD by welding, and it runs now 3700 revs in 5th gear on 120km/h (74mph)
    For fast accelerating he has to go to the 4th gear but it is much nicer drivable now!
  1. 1977 sports coupe rear axle ratio options info needed
    By heavyrolla in forum Toyota Garage
    Last Post: 04-15-2015, 04:10 AM
  2. 3.73 vs 3.91 diff which is better
    By boilerman in forum Toyota Garage
    Last Post: 10-10-2011, 09:00 PM
  3. trade welded diff for stock diff mx87 cressida
    By xsquintsx in forum Toyota Swap Meet
    Last Post: 07-01-2011, 05:17 PM
  4. 121 diff
    By robj in forum Mazda Garage
    Last Post: 09-18-2010, 11:40 AM
  5. oxygen sensor for air/fuel ratio
    By a121 in forum Mitsubishi Garage
    Last Post: 02-12-2010, 09:24 AM
