Results 1 to 8 of 8
Thread: Painting a valve cover
    Feb 2010
    Cleveland, Ohio
    1,608
    Hello all, I'm preparing to paint my 4G63 valve cover, and I'd like to do it in a black wrinkle finish with the raised lettering left natural. Usually I just sand away the raised surface after painting but that may prove difficult in this case since it's wrinkle finish. Has anyone tried spreading a thin coating of oil on the raised part, painting it, then wiping it off after the paint has dried? Any other suggestions?
    Feb 2010
    Cleveland, Ohio
    1,608
    Re: Painting a valve cover
    Quote Originally Posted by rkkopra73
    Applying oil to just the raised surfaces without it weeping over the edges is going to be difficult, let alone something funky happening while you apply the paint (the oil could move around). Wrinkle coat is still just paint at heart, and shouldn't be too difficult to sand. Depending on the intricacy of your raised edges, you could scrape the majority of the paint off with a razor blade held at an acute angle to the surface while the paint is still soft. At that point hard block the rest off, leaving a uniform grain and nice sharply defined edges. If the detail is excessive, using a razor blade may be labor intensive. If so, start with a course grit to knock it down to bare metal, then step up to a finer grit until you get to a graining of your liking.
    Robin
    Thanks for the advice...never thought of using a razor blade. The lettering's raised up a healthy amount and it's going on a crappy car so I have a little margin for error at least. Thanks...I'll try that!
    Jul 2007
    Sydney, Australia
    1,653
    I've sanded lettering away on a wrinkle finished cam cover before. Just wrap some emery tightly around a block of wood and carefully sand it away. You can sorta see it in this pic
    Feb 2010
    Cleveland, Ohio
    1,608
    Quote Originally Posted by tristinGrind
    Is this what youre looking at doing?
    YES :shock:
    I'm going to be "unlazy" and sand it off when it's done...hadn't thought of wiping it off while the paint's still tacky, I may try that!
    Jun 2010
    Brisbane, Australia
    341
    Do what Kev said.
    Oklahoma City
    762
    I used white lithium grease on my 20R valve cover and it worked great. I applied a very thin coating of the grease with a Q-tip and then painted the valve cover. I did have to do some sanding as using the grease did not leave a perfect line on the lettering of the valve cover. My next valve cover I will most likely sand back the paint rather than mask. The grease did make the job easier though.
    Not a great shot, but you can see the valve cover at least.
    Jun 2010
    Massachusetts
    33
    On past projects I had good results using very inexpensive water based kids paint / crafts paint. I had very good results using thick gel type finger paint. It's heavy thick consistency made for good coverage and crisp results. Came off real easy too. Good luck
    with your project.
    Apr 2012
    socal
    71
    I used brake cleaner/carb cleaner. Spray some into the cap, dip in a Q-tip and use it like a swab to remove the paint from the lettering. You will use a hand full of Q-tips but it's a simple way to localize what your doing. I tried the sanding method and found myself hitting parts I didn't intend.
  1. WTB 82 corolla 3TC Valve Cover!!!
    By Classicjdm in forum Toyota Garage
    Last Post: 03-10-2013, 07:09 AM
  2. 3SGTE Valve Cover
    By c_copperpot in forum Toyota Swap Meet
    Last Post: 12-27-2012, 09:09 PM
  3. WTB: Old RB20 valve cover set
    By c72c in forum Datsun/Nissan Swap Meet
    Last Post: 04-20-2012, 05:41 PM
  4. L24 Valve cover?
    By skyrine in forum Datsun/Nissan Garage
    Last Post: 01-18-2011, 04:25 AM
  5. Chromed/Polished OEM L24 Valve Cover
    By oniz in forum Datsun/Nissan Swap Meet
    Last Post: 04-19-2010, 01:58 AM
