Results 1 to 6 of 6
Thread: 3sg starter
    Jun 2012
    4
    3sg starter
    In the middle of a transplant and was wondering if anyone knows which starter to use?
    I have a 3sgte 2nd gen with a 2s bellhousing going into a te27, but was not sure which starter to use. I plan on using a 91-95 MR2 turbo flywheel. Mr2 have starters on tranny side so tgey wont work. Any suggestions are appreciated. Thanks..
    Aug 2007
    melbourne
    84
    Re: 3sg starter
    you need a 2s starter and altezza 3sge rwd fly wheel for it all to work fwd flywheel wont work .clutch fork has to move to much
    Jun 2012
    4
    Re: 3sg starter
    Quote Originally Posted by Celica RA45
    Now where would one find a 3sg rwd flywheel? Or is there something here in U.S that I can use.....3sfe maybe???
    Aug 2007
    melbourne
    84
    Re: 3sg starter
    i have a 3sge beams cusco super single here fly wheel clutch etc looking for 900 aussie plus postage
    Aug 2011
    25
    Re: 3sg starter
    1986-1989 celica gts (usdm) starter rests under the exhaust manifold - not over the transmission.
    that setup uses the 3sge and 5sfe flywheel, so your options are as such.
    5sfe flywheel: 225mm
    3sgte flywheel: 236mm
    so... if you do not already have the 3sgte flywheel, you could use the 3sge/5sfe (225mm) flywheel with an upgraded clutch kit and the above mentioned 1986-1989 celica gts starter.
    Jun 2012
    4
    Re: 3sg starter
    Quote Originally Posted by not12listen
    Thanks for the info...I will try that setup...
  1. Nissan Laurel C32 Motor Starter
    By Nismon in forum Datsun/Nissan Swap Meet
    Last Post: 01-06-2013, 08:26 AM
  2. L series starter/flywheel compatibility
    By familycar in forum Datsun/Nissan Garage
    Last Post: 12-22-2012, 11:45 AM
  3. starter question, 1970 hilux, 8RC engine
    By tonypiff in forum Toyota Garage
    Last Post: 08-31-2011, 01:42 AM
  4. 83 Challenger starter
    By BryanZ in forum Mitsubishi Garage
    Last Post: 10-31-2010, 02:01 AM
  5. Datsun 210 starter compatibility
    By Dave77 in forum Datsun/Nissan Garage
    Last Post: 10-21-2010, 01:01 AM
