Results 1 to 10 of 12
Thread: 67 Corona Help
    May 2010
    Springfield, OR
    100
    67 Corona Help
    about a year ago my dads Rona died... While i was driving it. It wouldnt spark, turns out it was the ignition. So we switched that out and it still wont run.
    Specs
    Bone stock 3r-c with toyoglide 2 speed.
    New Stuff.
    Coil
    Rotor
    Cap
    Plugs
    Rebuilt Carb
    Ignition Switch
    Condenser
    So heres the problem.
    It will crank over, we have strong spark. It will keep cranking and it'll act like its going to start but it will never actually run. We are starting to get fed up with it and dont have a clue what to do. So im wondering if anyone can shed some light on this subject, Is this a common problem with these cars?
    May 2010
    California
    59
    Re: 67 Corona Help
    You getting fuel? if you can't tell, pull the aircleaner off and drip a few drops of fresh clean gas down into the carb and see if it changes anything. just dont drop too much in there =p.
    May 2010
    Springfield, OR
    100
    Re: 67 Corona Help
    Quote Originally Posted by adamyee
    Already been tried. In the little peep hole on the side of the carb the level stays pretty much the same... if anything we are getting to much, but i doubt it.
    May 2010
    Springfield, OR
    100
    Re: 67 Corona Help
    Quote Originally Posted by asirike20
    surely there is a problem with the carb..........
    maybe it is blocked..............
    I dont think so because if i look through the butterflies i can see fuel at the bottom of the intake... :?
    Could the intake get clogged somehow?
    Oct 2009
    Sacramento, CA
    14
    Re: 67 Corona Help
    Check the timing??? I'm just sayin :tu:
    May 2010
    Springfield, OR
    100
    Re: 67 Corona Help
    Quote Originally Posted by Garlic Cruton
    Ah, that leads me to another dilema. The distributor does not move... no matter how hard I try and turn it(not trying too hard for fear of breaking it).
    I'm assuming this is not normal but I'm not sure, I'm not to familiar with this engine.
    May 2010
    California
    59
    Re: 67 Corona Help
    You are loosening the dizzy before you try and turn it right? Sorry if you take that wrong, but I've seen people try it before =P
    May 2010
    Springfield, OR
    100
    Re: 67 Corona Help
    Yes sir, Small clamp just under the dizzy holding to the block.
    May 2010
    California
    59
    Re: 67 Corona Help
    and the thing wont budge at all? does it still slide out of the block?
    May 2010
    Springfield, OR
    100
    Re: 67 Corona Help
    I haven't tried to take it out, but no, it doesn't budge when turning.
    :cry:
