Results 1 to 4 of 4
Thread: help to install a tacho to 3k
    Guest
    Re: help to install a tacho to 3k
    The trigger wire of the tach goes to the negative side of the coil.
    Mark
    Quote Originally Posted by asirike20
    does anyone know how to install a tacho gauge to a 3k motor in a rolla ke20?????????
    my one do not have one so i need to install........
    please help me........... thnks.....
    Here is a diagram for a quick reference
    Jun 2010
    Philippines
    73
    oooooooooooook thanks a lot guys........... its great........ :tu: :tu: :tu:
    but if it is an og one , i mean if it is driven by a cable , then is there any location on a 3k
    to connect the cable to the motor like a speedometer cable???????
    wow, a mechanical tach ? gotta wait for this! :shock: truly old school!
    Haven't seen a mechanical one bro.....
  1. Best Cam to Run (Install) ON 22R
    By boilerman in forum Toyota Garage
    Last Post: 12-31-2014, 04:04 PM
  2. Installing tacho into N360
    By benj in forum Honda Garage
    Last Post: 02-13-2013, 04:20 AM
  3. Wanted Starlet tacho instrument clocks with rev counter
    By TheGerman in forum Toyota Swap Meet
    Last Post: 12-14-2012, 10:58 PM
  4. 4cyl. Tacho. Function With 6cyl.?
    Last Post: 03-05-2012, 12:52 AM
  5. TE27 Tacho cluster RHD
    By parrot in forum Toyota Swap Meet
    Last Post: 10-01-2010, 07:15 AM
