Results 1 to 6 of 6
Thread: 2M - 4M Engine Block
    May 2011
    8
    Can anyone confirm whether the 2M and 4M engine blocks are the same?
    Mar 2008
    Boise, ID
    51
    Re: 2M - 4M Engine Block
    Talked with my dad on this. We both think that everything is the same except for the cylander bore. So every other gasket but the head gasket should work for you.
    Hope this helps
    May 2011
    8
    Thats' what I was thinking....I guess I'll have to try to be sure. I'll post the result...........Thanks ;-)
    May 2011
    8
    Got the 4M full gasket set.....It's good for the 2m except for the cylinder head gasket ( due to the larger bore)
    Jul 2012
    Orange County, CA
    116
    I broke down my block last week, crankshaft is stamped 2M, but the engine itself is a 4m. Mostly everything is the same. Rebuilding the block myself.
    Sep 2010
    australia
    39
    All M,2M and 4M and 5M run the same headgasket the only difference is between the early 4M and late is the timing cover bolts at the front,early are internal and late is external.Hpe this clears things up.And yes all the cranks from 2M on including 5M,7M have 2M stamped on them.
    Cheers Brett.
  1. WTB: 20r/22r short block engine (Central Florida)
    By te51 in forum Toyota Swap Meet
    Last Post: 08-08-2013, 12:51 AM
  2. 73 TE27 with a 3t block?
    By in forum Toyota Garage
    Last Post: 03-11-2013, 01:50 AM
  3. New on block
    By Mike L in forum Introduce Yourself
    Last Post: 10-12-2012, 02:29 AM
  4. Looking for ENGINE SHORT BLOCK 2TG - CELICA TA22
    By lukman in forum Toyota Garage
    Last Post: 05-22-2012, 11:49 PM
  5. WTB 1971 celica GT TA22 short block engine 2TG
    By lukman in forum Toyota Swap Meet
    Last Post: 05-17-2012, 12:58 AM
