Results 1 to 10 of 13
Thread: What is lightest/fastest Toyota/Lexus motor that fits te21?
    I have a 13b rotary in there now, but may be switching back to Toyoya...I'm sure most of you diehards will be pleased with that. The rotary is nice because of the weight aspect and the RPM's. I'm not concerned about period correct or anything. Something good for track and street. I'm sure there are a lot of different opinions but are there 6-cyl. that fit but still light and how much more work is it to get it to fit? Is it worth it from those that have done the conversion.
    Or better to go 4-cyl, (turbo/intercooler) etc. Just getting ideas. I've seen a Mazda RX-4 with a Toyota 2JZ-GE (But not sure how that would handle on the track with weight). The Orange one in pictures.
    Open for suggestions, again, doesn't need to be period correct, modern ok, probably better, track use and street, weight to HP main concern. And would need matching tranny 5-sp or 6-sp. Or stick with the rotary and just work on tuning that. Currently 13B GSLSE Street port with 48 Weber Downdraft IDA. matching 5-sp.
    Pictures of some I've seen. http://pix.kg/g/G6190329251105:1290329251105/scl
    Model below it on most of them.
    Guest
    Re: What is lightest/fastest Toyota/Lexus motor that fits te
    4AG would probably be best bet for lightness and power (especially with turbo/supercharging capabilities), but if you wanna go crazy Beams 3S-GE (or GTE) comes to mind. You could also go for the 2RZ-FE or 3RZ-FE (2.2 and 2.7 L respectively) Tacoma engines. I think the most beastly would be a 3.4 V6 from the Tacoma (with TRD supercharger). Obviously going straight six would require a lot more work than shoehorning some I4 or V6 in there.
    For my TE-27, my ideal non-original motor would have to be a stroked 4-AG running a set of 45mm sidedraft carbs.
    Thanks so much, I didn't even think about those Tacoma engines...
    Apr 2010
    Redondo Beach, CA
    14
    1UZ is all aluminum 8)
    Sep 2010
    Magna, UT
    689
    If anyone could ever make a v6 toyota work in a RWD configuration I would be all over that!! Too bad they all came in 4WD or FWD setups.
    Apr 2011
    United Arab Emirates, Dubai
    420
    Quote Originally Posted by UtahSleeper
    Good a place as any to ask this question then. :roll:
    You can drop a 1MZ-FE from a Camry into an AW11 or a SW20.
    This works because the engine is transversely mounted and you use a 3S-GE transmission from either an MR2 or a Celica which bolts straight up to the 1MZ-FE.
    Would it be possible to mount it longitudinally in the front of a car and use the 6 speed gearbox from the BEAMS black top 3S-GE powered Altezza RS200 or are they completely different?
    Jan 2009
    Mauka
    66
    Might be rare in Utah but Hawaii has loads of V6 2WD trucks.
    Sep 2010
    Magna, UT
    689
    Quote Originally Posted by ToolZ
    I think the rwd trans is different...............but I dont actually know for sure.......May have to do more research. Surprised I never put the 2 different things together.
    And last time I looked, it seemed like all of the yota trucks and suv's that were V6 also were only auto.....again, more research time lol.
    May 2011
    Los Angeles
    94
    u need to put a 2tg very respectful power its a twin cam and carbs also
    Mar 2011
    Qld
    33
    You could just rebuild the Rotary and go for a bridge port. Or turbo charge it.
    Or do both.
  1. 1977 Toyota Celica GT with Lexus V8 Engine Swap
    By tomas6791 in forum Toyota Garage
    Last Post: 09-19-2014, 10:49 PM
  2. WTB: Manual Trans & pedals that fits a 76 corona
    By vegascorona in forum Toyota Swap Meet
    Last Post: 08-11-2012, 07:28 AM
  3. Replies: 1
    Last Post: 10-23-2011, 07:03 AM
  4. East coast toyota/lexus parts
    By customcorona in forum Toyota Garage
    Last Post: 06-02-2011, 06:57 PM
  5. Toyota/Lexus news for RoadsterViking
    By toyotageek in forum Off-Topic
    Last Post: 09-05-2009, 05:37 AM
