Results 1 to 3 of 3
Thread: 74 Hilux Disk Conversion
    Sep 2009
    San Diego
    2
    Ive got a 74 Hilux Im in the process of doing a motor swap in. Its got drums all around, so while Im at it, Id like to switch to disks at least in the front.
    Anyone have any suggestions on what other toyota models would swap over fairly easily? Any tips on install?
    Hopefully something I can pull at a junk yard or something.
    Thanks!!
    Apr 2007
    Australia
    10
    Easiest option would be to find an RN40 or 41 Hilux with disc brakes. You just unbolt the whole stub axle and bolt it all up to your Hilux. You must make sure that you get the one with the upper and lower ball joints both pointing in a downward direction like on your early model Hilux. Get under the car and take a look - you'll see what I mean.
    Dec 2008
    Sydney, Australia
    6
    gianttomato I think you forgot to mention that the lower control arm may need a gentle grind to accomodate the disk brake stub axle's larger lower balljoint, funny cause you taught me that. Have a read here teenage; http://www.toymods.net/forums/showthread.php?t=37685 the rn16 has the same setup as the rn20s so it should be the same deal. once you get that stub axle all bolted up look into fj60 landcruiser 4 piston calipers as they bolt up to that stub axle and you can then run a peugeot 604 vented rotor once machined
  1. RN40 Hilux
    By Cody mackay92 in forum Toyota Garage
    Last Post: 01-30-2013, 01:28 AM
  2. Hilux 2.0 ------- My 71 Toyota Hilux
    By kingtoy in forum Toyota Garage
    Last Post: 04-21-2011, 11:52 PM
  3. New guy with two Hilux's
    By kevintothej in forum Introduce Yourself
    Last Post: 08-04-2010, 08:06 AM
  4. WTB 71 Hilux parts
    By kingtoy in forum Toyota Swap Meet
    Last Post: 07-24-2010, 03:38 AM
  5. Looking for donor rear vented disk brakes w/ int. e-brake
    By jt191 in forum Resto Tips, Wheels & Other Goodies
    Last Post: 06-13-2010, 07:03 AM
