Results 1 to 3 of 3
Thread: wiring problem? 78 accord
    once again this is for my 78 accord.....
    the radio taillights and dash lights wont come on the fuses are fine tho what could the problem be?
    Re: wiring problem? 78 accord
    figured out the radio but the dash lights and tails still dont work :?
    Mar 2010
    New Jersey
    24
    If you have a voltmeter handy, check for +12V to ground on both sides of the fuse. Also, check to see what the voltage is across the fuse. I'm leaning towards either a bad fuse or bad wiring connection somewhere. The fuses can look good, but still have an internal break that you can't see from the outside.
  1. WANTED: Zenki TE71 GT wiring diagram - Instrument Wiring
    By oldeskewltoy in forum Toyota Garage
    Last Post: 09-20-2014, 02:57 PM
  2. SOS hakosuka wiring problem
    By kgc10 gtx in forum Datsun/Nissan Garage
    Last Post: 07-15-2012, 01:35 AM
  3. rt135 od problem
    By oldskl in forum Toyota Garage
    Last Post: 10-13-2011, 09:34 PM
  4. HID conversion problem
    Last Post: 09-10-2011, 03:15 AM
  5. Problem with forum
    By cman in forum General Discussion, JNC News & FAQ
    Last Post: 08-23-2009, 04:33 AM
