Results 1 to 10 of 10
Thread: 2jzge swap into Mx32??
    Aug 2011
    Oregon
    29
    Hey guys so I知 looking into doing a 2jzge swap into my mx32. I like the 4m but it is burning oil right now and is in need of a rebuilt. I need something with a little more umph, so I知 looking for an upgrade. I知 still planning on keeping it just a daily cruiser, so I知 sticking with an automatic setup. My questions are how the difficult the swap is? What parts are needed? What needs to be modified? Pretty much anything that is needed to complete this swap. Also, if anyone else has done this swap, what is the range of cost of this complete swap (DIY swap and/or Shop installed)??
    From the research I致e done, I think these are the things needed to complete the swap:
    -Complete Engine Assembly
    Engine
    Automatic Transmission
    Wiring Harness
    ECU
    Alternator
    Power Steering
    Intake Manifold
    Exhaust Manifold
    -MX73 (MA6x) JZ Swap Motor Mount Brackets??
    -MX73 (GX71) Urethane Motor Mounts??
    -Front sump oil pan??
    -Modify Crossmember??
    -Driveshaft??
    -Fuel lines??
    I know some of you have done this swap already, so I would like to hear your opinions and suggestions. Much Appreciated
    Feb 2009
    Denver, CO
    127
    Re: 2jzge swap into Mx32??
    x7 2jz brackets will work
    front sump oil pan
    x3 draftshaft should work
    gas pedal that is compatable with 2jz
    2jz ac hoses to mod the fixture to x3
    make sure you clean the intake manifold, i had an issue with that.
    you might have an issue with the fuel pump. im changing out my stock one.
    1200 to 2000 for installation labor only.
    Dec 2009
    southern PA
    278
    depends how much you can source from a salvage yard and how much work you can do yourself.
    best advice, find someone who wrecked their sc300 or other jz powered car and buy the whole thing
    Aug 2011
    Oregon
    29
    Quote Originally Posted by onlyCressida4me
    front sump oil pan
    What gas pedal did you use?
    Quote Originally Posted by schassisowner
    Yeah i'm in the look out for some wrecked sc300 or gs300, hopefully a decent priced one. Fingers crossed.
    Feb 2009
    Denver, CO
    127
    gs300
    Aug 2011
    Oregon
    29
    Coolio. Hopefully I can just find a wrecked gs300, it seems that would be the best choice. Fingers crossed.
    Oct 2009
    Seattle
    146
    I have a good 4m if wanna go conservative
    Aug 2011
    Oregon
    29
    Question, so I have a gs300 harness w/ecu. Will 89 cressida or sc300 auto transmission fit with this setup correctly?
    Jan 2011
    Texas
    229
    SC300 transmission will bolt up. Not sure if the transmission harness plugs are the exact same as the GS.
    89 Cressida definitely wont bolt up (7M bellhousing). Might if you swap bell housings?
    I'd just stick with a JZ transmission out of an SC or GS.
    Aug 2011
    Oregon
    29
    Quote Originally Posted by jzcelica
    Yeah this was what I was thinking too. Seems like the sc300 transmission are a little bit cheaper but just hesitate to buy one since not sure of if the plugs will work with the harness.
  1. 8R swap?
    By damageinc86 in forum Toyota Garage
    Last Post: 01-13-2015, 05:34 PM
  2. MX32 1JZ help
    By clark_griswold in forum Toyota Garage
    Last Post: 08-09-2013, 11:55 PM
  3. 1gz-fe Vs 2jz VVTI n/a swap into cressida mx32 !!!
    By ni8kid in forum Toyota Garage
    Last Post: 05-29-2012, 09:39 AM
  4. 18r Swap to 20r
    By The Names Yota, Toyota in forum Toyota Garage
    Last Post: 04-18-2012, 08:09 PM
  5. 2JZGE in my MA70
    By DegreE in forum Toyota Garage
    Last Post: 03-31-2012, 01:27 PM
