Results 1 to 3 of 3
Thread: Vinyl car wraps
    Jan 2012
    South Dakota
    Vinyl car wraps
    Anyone had experience with using vinyl car wraps? I've got an Datsun 810 with nasty hail dents that I'd like to cover. A good repaint job is out of the question right now.
    Could I putty in the dents, sand smooth and the apply vinyl? There are some pretty boss looking color schemes that I think would look sweet.
    What say you ???
    Dec 2009
    Re: Vinyl car wraps
    yes that is possible. just make sure the car has a nice flat surface as any dent/crack or anything like that can be seen in your vinyl.
    If you do a proper vinyl job it will not be that much cheaper than painting a car as the preparations are the same and this is the most time consuming job and therefor pricy
    Mar 2011
    New Zealand
    Re: Vinyl car wraps
    I'm an apprentice signwriter and whole car wraps are very popular. If you can prep the car yourself, which pretty much involves cleaning the entire car THOROUGHLY, getting in every nook and cranny, removing all specks of tar etc (turps is the best option for removing tar), and then using another cleaning agent (such as iso propyl alcohol) to clean the greasy residue left by the turps, the application should be relatively cheap. As an idea, the vinyl we use is about $50NZD a metre and will last generally 5-8 years. Hope this helps you somewhat. Make sure they put the badges and what have you back on too, we have genuine RX-2 badges, Vauxhall Victor badges and the likes on the toolboxes at work that the boss has collected over the many years he's been doing it :lol:
  1. Fairlady Z Vinyl Sticker
    By gokiburix in forum Datsun/Nissan Swap Meet
    Last Post: 02-22-2012, 08:43 PM
  2. FS Mazda Car vinyl decals many models
    By lisasdecals in forum Mazda Swap Meet
    Last Post: 09-16-2011, 07:50 PM
  3. Old Skool Toyota (???/TEQ)?vinyl cut decals
    By gokiburix in forum Toyota Swap Meet
    Last Post: 07-07-2011, 07:19 PM
  4. Help, to remove paint dust from vinyl
    By schellerup in forum Mazda Garage
    Last Post: 08-24-2010, 03:12 PM
  5. I need to have a vinyl sticker made!
    By mojocoggo in forum Wheels Swap Meet
    Last Post: 08-05-2010, 09:51 PM
