Results 1 to 10 of 18
Thread: Corona Mark II rear brake conversion
    Aug 2009
    Spokane, WA
    280
    Hello, I have a 73 Corona Mark II. I am still really new to all of this. This is my first old car and I am looking for information regarding the rear brakes. I know for a lot of the newer cars you can convert rear drum brakes to disc brakes. I am curious if the same is possible for these cars. I would like to know if any cars around this era had rear disc brakes and if there is any that are capable of being altered to fit. Thanks for any information.
    Aug 2009
    Albuquerque
    19
    If the 73 corona mkII has the same size rear end as a same year Celica, then an AE86 GTS rear end will fit with some slight modification of the position of the mounts themselves.
    Jun 2008
    Los Angeles, California
    573
    markII
    I converted my MarkII to 1980 Supra rare end. wasn't easy.
    Apr 2007
    Australia
    10
    I have a few of these Mk2s at home.
    One of them I slotted in a Hilux RN40 diff and converted it to discs - used 307mm JZA80 rotors and Celica ST205 rear calipers.
    With another, I just used an MS112 disc brake rear end - had to cut off the Crown mounts, had the Corona Mk2 mounts welded on and bolted the whole lot in. Tailshaft just bolted straight up. This diff is a little wider
    (40mm - 20mm per side) than the Mk2 one so if you have alloy wheels and guard clearance is already critical, then after this conversion they will rub for sure.
    I should highlight that boththe above conversions are 5 stud...you can use MS65 front hubs and discs to convert the front to 5 stud.
    If you're not interested in converting to 5 stud, then here in Aus we also got a Corona model ST141 - some of these came out with rear disc brakes. I'm led to believe that with minimal work these can be made to fit.
    Aug 2009
    Spokane, WA
    280
    Help
    Ok... so I have been unable to find any of the mentioned cars above for a reasonable price. Over here in Japan all of those cars seem to be pretty expensive around 4000 to 8000 and don't seem to have any around that have been wrecked. I really want to get the parts to do the swap. Is there any other cars that will work? Thanks for any help you can provide
    Feb 2009
    Northridge, CA
    169
    Re: Help
    Quote Originally Posted by theunstated
    This car is hard to find?
    If you want to fit a F or G type axle (Hilux/HiAce/etc.), I can tell you an easy way to retrofit disc brakes to that axle.
    Aug 2009
    Spokane, WA
    280
    Celica Supra
    That's a celica supra correct? Over here it is a Celica XX. It seems that there are even less of those over here than the other cars listed above. They run from around 6000 - 8000 depending on condition which is a little more than I want to spend on just a rear axle/diff/brakes. As far as the hilux or the hiAce the trucks seem to be way out of price range 8000 - 15000 for the newer ones. Still looking at the HiAce for options. Any others?
    Feb 2009
    Northridge, CA
    169
    Yes, that is a Celica XX...see the fender mirrors, bumpers, grill, and front license plate? :lol:
    Anything with a 7.5 we can make happen. Maybe better to get a housing modded in OZ and get it shipped to you...
    Aug 2009
    Spokane, WA
    280
    thanks
    I am kinda new to all of this, So be patient please. Get a housing modded in OZ? I assume that is the diff but what is OZ?
    Feb 2009
    Northridge, CA
    169
    OZ = Australia
    It may be cheaper for you to buy a AE86 or MA45/46 axle in Australia, have it modded to fit your car, and shipped to JP.
  1. red R30 rear seats and R31 Hasemi rear brake pads BNIB
    By familycar in forum Datsun/Nissan Swap Meet
    Last Post: 06-13-2015, 06:07 PM
  2. Which handbrake cables for Ae86 rear Disc conversion on KE30
    By KustomS in forum Resto Tips, Wheels & Other Goodies
    Last Post: 03-04-2014, 08:08 PM
  3. Modern Motorsports extreme 13" rear disc brake conversion
    By takayuki in forum Datsun/Nissan Swap Meet
    Last Post: 10-29-2012, 02:41 AM
  4. Replies: 2
    Last Post: 07-20-2011, 10:46 PM
  5. 1973 Corona Mark II Sedan Rear Bumper for sale.......
    By terolla in forum Toyota Garage
    Last Post: 12-16-2010, 12:34 AM
