Results 1 to 10 of 14
Thread: 78 Corona Bumper Removal pic/procedure request
    Jan 2011
    Goodyear AZ
    53
    Im trying to remove my rear bumper just to see how it would look. I'm liking the old school no bumper look but its a P.I.T.A. All the necessary bolts are removed but it feels like Im missing something, I see there are like rams pressed into the chassis, not sure if its just that old to where its near impossible to remove it but it should come out.
    To the point, does anyone have a picture of a T100 corona without bumpers or has any input on how to do it?
    Administrator JNC's Avatar
    Mar 2007
    Socal
    1,644
    Re: 78 Corona Bumper Removal pic/procedure request
    there's is at least one guy here who's put later model plastic bumper/spoiler
    and it looks real good
    that could be an option?
    -Matt
    Jan 2011
    Goodyear AZ
    53
    possibly but im REALLY leaning toward the bumperless, if it doesn't work out then I'll see from there. i guess i gotta search harder lol
    Sep 2009
    Tucson, Az
    222
    you could do a tucked in bumper which what i did to mine or if you could find a jdm chome bumper would be way better. There is a guy from 1stgencelica and i believe he is called bullit on that forum. contact him if he has some rt bumpers.
    GL on the project. Wish i still had mine.
    Btw, if you want to do the same like what i did, you will need to drill holes to let the gas out. wear some goggles as it will squirt out dry substance everywhere. After doing that, push it in and position it to how far u want it then tack weld (tube shock absorber) in place. Once u get it squared away, weld all the way around.
    Jan 2011
    Goodyear AZ
    53
    dammmn thats some crazy shit lol. ill keep my mind open on that but thanks for the tip on bullit, sounds filipino
    4x 12mm nuts, 2 each side above the rear shackles. thats all my bumpers have ever had to hold them on. they look nice without the rear bar.
    Jan 2011
    Goodyear AZ
    53
    bringing back this topic. say i don't have a tack welder, could i ghettofy it by using jb weld to plug up the drilled hole?
    Sep 2009
    Tucson, Az
    222
    If I remember this right I think you can just drill a hole on other sleeve on both sides and put a nut and bolt. That will hold the bumper in place if u don't have a welder.
    Jan 2011
    Goodyear AZ
    53
    ohhhh ok that sounds a bit easier. ill will try it out for sure. thanks man
    Jan 2011
    Goodyear AZ
    53
    think im failing with it. drilled into the bigger piston that fits in the chassis and nothing came out or movement, then theres the smaller and thicker piston which is taking too long to drill into
  1. [FS] NOS taillights, bumper, pins: corolla/cressida/corona
    By stefaantje in forum Toyota Swap Meet
    Last Post: 12-17-2012, 06:09 PM
  2. Remove Corona front bumper
    By ChaseCorona in forum Toyota Garage
    Last Post: 07-09-2012, 12:35 PM
  3. WTB RT43 corona fender, bumper grille
    By Skip_danger in forum Toyota Swap Meet
    Last Post: 08-16-2011, 12:55 AM
  4. corona rt7 front bumper
    By yellow_sub in forum Toyota Swap Meet
    Last Post: 01-04-2011, 09:40 PM
  5. Mikuni Solex Carb Adjustment Screws and Procedure
    By frost_zime in forum Resto Tips, Wheels & Other Goodies
    Last Post: 03-13-2010, 06:35 AM
