Results 1 to 10 of 15
Thread: rear lowering(leafs)and stiffening a 77 corona questions...
    Oct 2008
    Forty-Fort, PA
    105
    So i bought a lowering block setup for a toyota hilux 2wd,thinking same underpinnings,but it was wrong,bigger u-bolts...
    So the rear needs to go down 1/1.5 inches,and the og leafs are tired.Seems like i could call afco and have them make me leafs,but does anybody know the og spring rates?Does anybody make a kit?
    Any info would be appreciated,my baby needs to be lower :mrgreen: also a picture of said rear below...
    fontana, CA
    173
    have you tried going to a 4x4 shop? sometimes they do work on leaf springs and would be willing to do a lowering leaf.
    theres a spot out here in cali that does them for 450.
    Oct 2008
    Forty-Fort, PA
    105
    Nobody?..guess I'll just have leafs made :td:
    Jul 2009
    Austin
    104
    you have to drill your stock stuff to get the u-bolts to work... im pretty sure everyone does that.
    Aug 2009
    Albuquerque
    19
    I just used leaf spring spacers on mine. I cut the stock ubolts above the thread, added an extension to them, welded the extensions in place, and placed it back on the car. Not the greatest fix, but it works.
    This is how mine came out.
    Feb 2009
    oregon city
    74
    I had some U-bolts for my Corolla custom made at a local spring shop. The guy saw my old one and instantly said "Suzuki Samurai?"
    That could be a lead.
    Apr 2009
    Central Fl
    196
    just go to tractor supply or something and get Stainless All thread get a piece of 3in pipe and make u-bolts. I made my own using 3 in pinion cut blocks and no problems at all. But i wouldmlike a new set of springs or a stiffer set
    Apr 2009
    albuquerque, nm
    13
    Hey superboosted. Just go to a 4x4 suspension place. Just like the other guy said. Tell em to make longer u bolts for your lowering blocks. If they can't do it they know where to send you, cause these guys are always lifting or lowering trucks. Also, if your springs are weak, go to your local parts store and get a spring helper kit. I have two corollas and one has the helper spring kit. Handles way better than the one without. Cost thirty bucks.
    Oct 2008
    Forty-Fort, PA
    105
    I was assuming the helper kits also lifted the rear...they say that on the box,as i had em' in my hand two days ago... :?
    Apr 2009
    albuquerque, nm
    13
    Ok. That might be true. So for thirty bucks slap them on, find out how much they lift the car if any, cause remember I have two corolla's, one with and one without, and the one with does'nt seem lifted but maybe an inch. Then have your ubolts built to lower the car with your lowering blocks.
  1. Help with lowering my 79 corona
    By ChaseCorona in forum Toyota Garage
    Last Post: 05-31-2014, 03:03 AM
  2. RT40 Corona Questions
    By c_copperpot in forum Toyota Garage
    Last Post: 04-09-2013, 03:17 AM
  3. Lowering a 85 Celica Gt questions
    By 85Celi in forum Toyota Garage
    Last Post: 12-06-2012, 07:08 PM
  4. lowering my 70 corona mark 2 wagon
    Last Post: 12-26-2010, 09:28 PM
  5. Corona lowering options
    By Yotatoy in forum Toyota Garage
    Last Post: 07-29-2009, 01:18 AM
