Results 1 to 10 of 15
Thread: The Mazda (TA13L) Parkway Rotary 26 Bus
    Nov 2011
    Diego Martin, Trinidad W.I.
    55
    This is the rare of the rarest in Mazda Rotary History with only 44 made from Feb.1974~Jul.1976 the Parkway Rotary Bus is one cool ride notably with its TQX gearbox and select-sync differential...There are about 4 that still exsist in Japan and one on the road after getting recomissioned.
    Here are the technical specs of the TA13L...
    Pics later
    Nov 2011
    55
    Re: The Mazda (TA13L) Parkway Rotary 26 Bus
    TA13L specs:
    Make: Mazda
    Model: Parkway Rotary 26 Bus
    Chassis-code: TA13L
    Year(s)-produced: 1974~76
    Total-production: 44
    Model-type: 22-seater (low line), 26-seater Deluxe & 26-seater Super Deluxe
    Options: A/C
    Body-style: 3-door bus
    Body-length: 6195 mm
    Body-width: 1980 mm
    Body-height: 2280 mm (22-seater)/2310 mm (26-seater)
    Wheelbase: 3285 mm
    Front-track: 1525 mm
    Rear-track: 1470 mm
    Ground-clearance: 180 mm
    Curb-weight: 3210 kg (22-seater), 2835 kg Deluxe, 3260 kg Super Deluxe
    Engine-code: 13B
    Engine-type: twin-rotor Wankel
    Engine-dimensions: 588x714x661 mm
    Engine-weight: 151 kg
    Combustion chamber volume: 654 cc x 2
    Displacement: 1308 cc
    Compression-ratio: 9.4:1
    Compression-pressure: 9.0 kg/cm2 @ 280 rpm
    Operating oil pressure: 11.0 kg/cm2
    Induction: single 4-bbl downdraft Hitachi carburettor (REAPS)
    Ignition: single distributor (twin-points)
    Firing-order: 1-2
    Max.power: 135 ps @ 6500 rpm
    Max.torque: 132 lb-ft (18.3 kg-m) @ 4000 rpm
    Port-timing: Intake opening @ 32 deg ATDC
    Intake closing @ 40 deg ABDC
    Exhaust opening @ 71 deg BBDC
    Exhaust closing @ 48 deg ATDC
    Oil-capacity: 6.4 l
    Coolant-capacity: 11.0 l
    Thermostat-type: wax (opening temp 82 +/- 1.5 deg C and fully open @ 95 deg C)
    Point-gap: 0.45 +/- 0.05 mm
    Dwell-angle: 58 deg +/- 3 deg
    Idle-speed: 820 rpm
    Ignition-timing: 20 deg BTDC (Leading) @ 720 rpm
    15 deg BTDC (Trailing) @ 720 rpm
    Capacitor-value: 0.24~0.30 microfarad
    Plug-type: NGK B7EM or B8EM
    Plug-gap: 0.60~0.70 mm
    Electrical: 12v w/NS70 65Ah battery
    Drive-layout: cab over engine (longitudinal)/rear-wheel-drive
    Transmission: 5-speed torque-glide manual gearbox w/select-sync differential
    Gear-ratios: 1st-5.376:1
    2nd-2.608:1
    3rd-1.693:1
    4th-1.000:1
    Rev-5.495:1
    Final-6.667:1
    Clutch dimensions: 225x150x3.5 mm
    Trans-capacity: 2.8 l
    Suspension: front-beam axle w/leaf springs, sway bar and telescopic shocks
    rear-live axle w/leaf springs and telescopic shocks
    Brakes: front-drum w/two leading shoes (servo-assisted)
    rear-drum w/leading and trailing shoes (servo-assisted)
    Brake master dia.: 1"
    Servo dia.: 9"
    Front wheel cyl dia.: 1-1/8"
    Rear wheel cyl dia.: 1"
    Front drum dia.: 320 mm
    Rear drum dia.: 320 mm
    Stopping distance: 13.5 m from 50 km/h
    Steering: recirculating-ball (manual)
    Steering-ratio: 28.9:1
    Turning-radius: 6.7 m
    Turns lock-to-lock: 4.7
    King pin angle inclination: 7 deg 00 min
    Camber angle: 1 deg 30 min +/- 30 min
    Steering wheel dia.: 420 mm
    Tire-size: 6.50-16-8 (4.25 kg/cm2 front)/(4.0-4.25 kg/cm2 rear)
    Rim-size: 4.50E-16SDC
    Fuel tank capacity: 140 l
    Top speed: 75 mph (120 km/h)
    Nov 2011
    55
    First pic is one of the four buses that remain and the rest is one that is being re-done...
    Aug 2010
    perth western australia
    56
    That looks like a rare find mate, well done.
    Feb 2007
    Canada
    179
    Heck of a find. Thanks for sharing with us.
    Nov 2011
    55
    Thanks lol here's a little more of the 13L...
    Nov 2011
    55
    After the body work...
    Nov 2011
    ontario
    3
    That is by far the most amazing bus I have ever seen. Excellent find! :tu:
    Jun 2008
    Tampa FL
    125
    :tu: Amazing! Its Impressive that the 13B can manage to power a vehicle of that size
    Jun 2010
    Brisbane, Australia
    79
    Quote Originally Posted by RX-2Fan
    It couldn't really! ops: That's why only 44 were ever made! 8)
    Cheers,
    Danny
  1. Hello from Canada - Mazda Rotary guy with 72 616
    By JoeFerg in forum Introduce Yourself
    Last Post: 09-07-2012, 11:48 PM
  2. Mazda Rotary Pickup For Sale
    By r100guy in forum Ad / Auction Finds
    Last Post: 11-21-2011, 01:40 AM
  3. Mazda Rotary Pickup
    By ShantJ in forum Mazda Garage
    Last Post: 08-31-2011, 10:58 PM
  4. Mazda Rotary Engine ECU and trans
    By 2stroketurbo in forum Mazda Swap Meet
    Last Post: 02-03-2011, 05:26 AM
  5. Pre-85 Mazda Rotary Registry
    By madaz in forum Mazda Garage
    Last Post: 05-05-2010, 06:00 AM
