Page 1 of 5 123 ... LastLast
Results 1 to 10 of 50
Thread: The Mazda (M13P) Luce Rotary Coupe RX87
    Nov 2011
    Diego Martin, Trinidad W.I.
    55
    This thread is for the appreciation and technical specs of the 1969-71 Mazda M13P Luce Rotary Coupe (R130) RX87...Feel free to post pics, questions etc. for this rare piece of Mazda Rotary History...
    Nov 2011
    55
    Re: The Mazda (M13P) Luce Rotary Coupe RX87
    Make: Mazda
    Model: Luce Rotary Coupe (R130)
    Options: P/W, P/S & A/C
    Model type: (RX87 SDX-A A/C, P/S & P/W. 1970~71)
    (RX88 DX-B A/C & P/S. Oct.1969-Oct.1970)
    (RX89 DX-PS only. 1970)
    Body style: 2-door pillar less coupe
    Seating capacity: 5
    Chassis-code: M13P
    Year(s)-produced: 1969-71
    Total-production: 976 (1969-542/1970-431/1971-3)
    Body-length: 4585 mm
    Body-width: 1635 mm
    Body-height: 1385 mm
    Wheelbase: 2580 mm
    Front-track: 1330 mm
    Rear-track: 1325 mm
    Ground-clearance: 185 mm
    Turning-radius: 5.3 m
    Curb-weight: 1255 kg (SDX-A)/1185 kg (DX-B) & (DX-PS)
    Engine-code: 13A
    Engine-type: twin-rotor Wankel
    Engine dimensions: 565x590x555 mm
    Engine weight: 146 kg
    Combustion chamber volume: 655 cc x 2
    Displacement: 1310 cc
    Compression-ratio: 9.1:1
    Compression-pressure: 9.2 kg/cm2 @ 280 rpm
    Firing-order: 1-2
    Induction: single 4-bbl Hitachi carburettor (2D2834X)
    Ignition: twin distributor (points-type)
    Max.power-output: 126 ps @ 6000 rpm
    Max.torque-output: 127 lb-ft (17.5 kg-m) @ 3500 rpm
    Port timing: intake opening 32deg ATDC
    intake closing 45deg ABDC
    exhaust opening 77deg BBDC
    exhaust closing 36deg ATDC
    Idle speed: 700 rpm
    Points gap: 0.45 mm +/- 0.05 mm
    Dwell angle: 58 deg +/- 3 deg
    Leading timing: 5 deg BTDC @ 650 rpm
    Trailing timing: 0 deg TDC @ 650 rpm
    Plug lead type: HP5-10F
    Distributor model: Leading (TVB-2ML)/Trailing (TVB-2NR)
    Capacitors: 27 micro farads +/- 10%
    Spark Plugs: NGK B7EE/B8EE or B9EPD
    Plug Gap: 0.6 mm
    Engine oil capacity: 5.0 l
    Coolant capacity: 8.8 l
    Thermostat type: wax (opening temp. 82 deg +/- 1.5 deg and fully open @ 95 deg)
    Battery model: NS60L 45Ah
    Starter model: MV1.0/12XL (1.0ps)
    Alternator model: AG2060T (0.56W) 13.5-15.0 v
    Drive-layout: front mounted engine (longitudinal), front-wheel-drive
    Transmission: 4-speed synchronized manual
    Clutch pedal height: 195 mm
    Clutch free play: 0.5~30.0 mm
    Suspension: independent front with upper and lower wishbones with telescopic shocks
    independent rear with trailing arms with coil springs and shocks
    Vehicle height from fender center line: front 404 mm +/- 10 mm
    rear 339 mm +/- 10 mm
    Front wheel caster trail: 1.00 mm
    Front wheel side slip: 0 +/- 3.00 mm
    Front wheel toe: 3 +/- 3.00 mm
    Rear wheel camber offset: 7.00 mm
    Rear wheel toe-in: 1.5 +/- 2.5 mm
    Rear wheel camber: 1 deg 05 min +/- 30 min
    Front axle shaft length: 417 mm
    Front axle dia.: 31 mm
    Brakes: disc/front - drum/rear (servo assisted)
    Hand brake adj.: 3~10 notches
    Brake master cyl. dia.: 7/8"
    Front caliper piston dia.: 2-1/4"
    Rear wheel cyl. dia.: 13/16"
    Stopping dist.: 14.0 m from 50 km/h
    Steering: rack and pinion (power assisted)
    Steering gear ratio: 19.3:1
    Steering wheel dia.: 400 mm
    P/S fluid & capacity: ATF fluid (1.0l capacity) A40 belt
    P/S pressure: 50 kg/cm2
    Gear ratios: 1st-3.333:1
    2nd-2.056:1
    3rd-1.292:1
    4th-0.964:1
    Rev-3.727:1
    Final-4.875:1 (39T ring gear/8T pinion)
    Final drive oil: SAE90 (GL-5) 1.3l capacity
    Tires: 165HR15 (1.8-2.0 kg/cm2 front - 1.4-1.6 kg/cm2 rear)
    Rim size: 4Jx15WDC
    Top speed: 118 mph (190 km/h)
    Fuel tank capacity: 65l
    Mileage: 11.5 km/l @ 60 km/h
    Nov 2011
    55
    Some pics of the Luce M13P...
    Nov 2011
    55
    Some matics of the M13P...
    Nov 2011
    55
    The 13A...
    Dec 2009
    Dongducheon, Korea
    330
    Nice tread RotorKing
    Bless up
    Nov 2010
    Melbourne Australia
    103
    Amazing car and beautiful steering wheel :wink:
    Nov 2011
    55
    Enjoying your vids wasabicars and I always was fascinated with the M13P...keep 'em coming!!!
    Nov 2011
    55
    This is a montage and a closer look at a mint all original RX87 with spider webs and all lol...Although these cars were only RHD the firewall did have blank holes for LHD...
    Nov 2011
    55
    Here's one getting started after 24 years sleeping...enjoy and watch it in 480p for better quality...
    http://youtu.be/6q2iwamj6YU
    http://youtu.be/Nq6kL-RYaIY
  1. R130 Luce Coupe
    By Myron Vernis in forum Mazda Garage
    Last Post: 12-05-2014, 10:35 PM
  2. WTB: Anything related to the R130 Luce Coupe
    By Myron Vernis in forum Mazda Swap Meet
    Last Post: 11-29-2014, 02:16 AM
  3. 67 Mazda Luce Estate
    By ratmaz in forum Mazda Garage
    Last Post: 07-30-2012, 11:36 AM
  4. Abandoned Luce Coupe - year?
    By RX-2Fan in forum Mazda Garage
    Last Post: 03-24-2012, 06:03 AM
  5. My Mazda Luce Rotary Coupe
    By madaz in forum Mazda Garage
    Last Post: 01-20-2010, 06:58 AM
