Results 1 to 7 of 7
Thread: still 3t issue
    Jul 2009
    Austin
    104
    still 3t issue
    Alright well heres the deal.
    My car either misfires or doesnt fire at all. it tends to swich in between whenever it likes. I have my assumption what are yours?
    Jan 2009
    LaPine, or
    259
    distributor 180 out?
    Jul 2009
    Austin
    104
    i doubt it... its been 180* out before and it wont even start like that
    Jul 2009
    Austin
    104
    took 3 months but shes a beast. thanks guys
    Jan 2007
    3,108
    I assume you checked all the basic stuff like plugs/wires, compression, etc?
    Does it run lean?
    Jul 2009
    Austin
    104
    i replaced all that. The pos weber didnt have a return line cand the float bowl was full so it over flowed making the car uber rich shooting out black smoke and yup, fouling plugs. so it was a carb issue causing all of this. stock carb, new plugs, and lots of seafoam fixed it.
    Dec 2007
    Victoria BC Canada
    42
    I'm pretty sure a weber carb is not supposed to have a return line. The float and float needle regulate the float level. If the carb is overflowing either the float needle is just stuck (happens if the carb is gummed up or corroded inside) or your fuel pressure is way too high (should be 3-5 psi).
  1. Rx2 pitman issue
    By ozzyincali in forum Mazda Garage
    Last Post: 02-19-2014, 10:26 PM
  2. Mx32 issue
    By thatdeafguy in forum Toyota Garage
    Last Post: 07-08-2011, 12:16 AM
  3. KE30 Carb issue
    By jakob in forum Toyota Garage
    Last Post: 10-18-2010, 11:44 AM
  4. MAX POWER DEC. 2009 issue ???
    By toji004 in forum Off-Topic
    Last Post: 01-20-2010, 10:01 PM
