Results 1 to 6 of 6
Thread: How-To: Repainting Automotive Plastics
    Jul 2011
    fontana
    16
    Re: How-To: Repainting Automotive Plastics
    where the pics?
    Feb 2011
    Florida
    41
    this thread is worth a penny
    Oklahoma City
    762
    Another good tip, try to pull the masking off before the paint has dried. I usually wait about 10-15 mins for the paint to tack up. You are less likely to pull up the paint with the mask if it is still soft. If there is lettering on the part, I did a steering column surround that had 'Hazards' on it, a thin coat of oil/grease/vaseline works as a mask as well. After the paint has dried, just wash the part with warm soapy water. The grease/vaseline will break down and lift the paint with it. I will try to take some pics of the column tonight. If the color is available in the Krylon Fusion line, then you can skip the primer part. In all, great write up!
    Feb 2010
    Cleveland, Ohio
    1,608
    Great post! I'd like to add, I found a great velvety/semigloss black colour for cheap called "Touch N' Tone" available in some local Drug Mart stores, it lays down easy and looks great! The finish also seems fairly durable. Best part is it's cheap! http://paint-and-supplies.hardwarestore ... 60083.aspx
    Jun 2011
    Perth, Western Australia
    32
    how do you replace the plastic chrome on interior pieces
    Jan 2012
    Qld
    94
    have to get it rechromed
  1. Automotive Artwork
    By dsalni in forum Universal Parts Swap Meet
    Last Post: 06-23-2015, 08:23 AM
  2. Any Automotive Tin Collectors ?
    By Robb in forum Off-Topic
    Last Post: 01-28-2015, 12:18 AM
  3. Automotive Illustration Services.
    By yotajunky in forum Other Marques Swap Meet
    Last Post: 04-01-2013, 07:20 PM
  4. Automotive Guidebook of Japan -Six Volumes
    By r100guy in forum Wheels Swap Meet
    Last Post: 01-04-2011, 03:33 PM
  5. Five Best Automotive Backsides
    By Lincoln Stax in forum Off-Topic
    Last Post: 11-12-2010, 01:45 PM
