Results 1 to 10 of 16
Thread: Laurel C31 project
    Laurel C31 project
    hi all,
    been motivated by everybody around here, so I started planning on rebuilding my laurel.
    I started last year on fixing minor things gradually until I did a whole engine rebuild, that was my fist time ever. I'm going to post photos of the car from early stages, the car now is in the body shop for lot of body work and new fresh paint job ( hope it looks good ). Now I leave you with this video checking the revs of the engine.
    http://www. youtube.com/watch?v=FtigC2ZcaLs (I don't know if rules allow links!??)
    tell me your thoughts about it.
    Re: Laurel C31 project
    here are some pics of the car before working on it :mrgreen: 8)
    that was about a year ago................. :shock: :twisted:
    Apr 2008
    christchurch, new zealand
    69
    nice to see another C31 around. looks fairly tidy. plans for the old girl?
    heres my one viewtopic.php?f=7&t=12546
    thanks for passing by
    as for plans I only wanted to restore it to a healthy condition
    engine had trouble overheating for two years :shock: , but it just worked without fail 8) I really like the L series of engines, drive train sucks ( previous driver was a real push it to the limit man and fast driver), don't get me wrong that I just recently got the car, its my family car since we bought it from the dealer and the above driver is a cousin of mine
    heres some pics of the inside of the car after removing interior carpet (darn stray cats slipped inside while driver's window open and gave birth for 4 kittens had hell of time trying to scare her out :evil:
    8)
    had major rust on the outside frame and inside the trunk.
    one thing that I like about laurels is that they share lots of thing with skylines, wish I could buy one, went to paint shop last saturday for a friend of mine that was searching for a good painter to paint his nissan laurel altima (cefiro A31), while there my eyes picked up a skyline with cool ring (net style) covered in dust, asked the worker about it he said that the owner brought it a year ago since then he didn't come back for it :|
    checked through the window and it was without engine and gearbox
    this is what the L20 (6 cyl.) looked like before rebuild
    :x
    lots of grime due to failed power steering pump and etc..., engine was overheating a lot but it survived somehow
    generally I only shaved the head (minor welding as corrosion ate the alloy round the cooling holes), the short block just got cleaned with wd40 and wire brushed for new coat of paint.
    the valves were cleaned from carbon deposits (that stuff is as hard as steel) couldn't remove with screw driver nor carb cleaner, last I used the wire brush and bingo!! cleaned
    sadly didn't have grinding tools (paste and stick) to match the edges of the valve to the head :?
    assembled the short block with new rod bearings (used ca18 rod bearings) and new main bearings (only the main bearing wasn't used as I didn't know to trim it so it would get the correct clearance with the crank.
    new timing set (chain and brackets and tensioner) the guy at the parts store told me to use new ones so that I don't run into problems after finishing the rebuild.
    I was thinking about my engine, that it have a dished type pistons and the head chambers were like kidneys; the head number is '05L'. could it be that this carby engine is non other than a stripped L20ET ??? :?
    paint shop finished painting the car and got new tires
    I really think that I need enkei rims (gold or silver mesh) type, what do you guys think
    Sep 2010
    Magna, UT
    689
    Looking good so far. Nice clean up.
    thanks for passing by ...
    went out for a ride in it and came back to find the brake lights on while the car is turned off :shock:
    checked the brake light switch and seemed ok..., then I found this yellow plastic pieces on the carpet.
    it was the plastic button that turned the switch off, a quick search on the net for part number and I found that it was the same for most datsun cars (280zx, 200sx, sunny), still no part number though :x
    can anyone give me a hint about the following:
    while driving the car when changing gears I feel a strong metal knock sound coming from the back of the car, I replaced the gearbox mount, but still I hear that sound ?? could it be worn bushings in the diff area ?
    Apr 2008
    69
    these are the wheels i have lying around that i would like to fit to my laurel at some point. they arent enkeis but are a good brand.
    filthy
    $70 worth of stainless steel bolts :shock:
    cleaned up with a quick wipe with the centre caps and bolts installed as well as my datsun valve caps
    before and after comparison
    finally after some time, fitted to my bluebird. looks the biz too with my new jdm no. plate.
    as for the knocking noise, it could possibly be too much clearance in the diff between the pinion and crown wheel. does it do it when you put your foot on the clutch or when you go on and off the accelerator pedal?
    those rims are cool, what I'm looking for is the kind of rims that were on the HR31 (mesh rims)....
    I saw a skyline coupe HR31 with those rims (only the body, no engine or gearbox) asked around about it but it seems the owner ditched it here for a paint job a year ago and didn't come back for it :evil:
    as for the diff problem, I suspected that I might be running short on teeth, didn't have the chance to check nor money to fix. I was thinking of taking a cefiro a31 gts-r diff and fitting it in, but recently I spent lots of money overhauling rear brakes so that would be a waste, and from my user manual the diff for the sedan c31 is H190 which is supposed to be strong even for RB20 and VG30 8)
    the problem happens while shifting (engaging and disengaging the clutch pedal) and increasingly if the RPM is HIGH, say from 2800 - :twisted: RPM :mrgreen:
    I thought you said you had a wagon 910, Not that beautiful 910 :shock: (rare to see them these days as most datsun s are)
  1. Some JNC Winter Fun with my C32 Laurel
    By 260z in forum Datsun/Nissan Garage
    Last Post: 12-28-2014, 06:24 PM
  2. My Laurel
    By Never Lift Garage in forum General Discussion, JNC News & FAQ
    Last Post: 06-22-2014, 10:46 PM
  3. 510 - c30 laurel
    By Eric in forum Resto Tips, Wheels & Other Goodies
    Last Post: 12-29-2010, 03:24 PM
  4. pic req: Nissan Laurel C32
    By Norbe in forum Datsun/Nissan Garage
    Last Post: 10-29-2010, 03:46 AM
  5. project rusty!! my new gto project !! new member!
    By j.c grime in forum Mitsubishi Garage
    Last Post: 01-07-2010, 08:52 AM
