Results 1 to 6 of 6
Thread: mazda rx2 front suspension ?
    Aug 2011
    norcal
    66
    well i pulled all my suspension off the front of my 1973 mazda rx2 and i found that one of my tociko shocks was bent (shock rod )im using mazda fb front struts and re speed coil overs.Im re-doing the front end: respeed tubular control arms +1" longer with miata ball joints ,respeed camber plates and bump steer spacers,I will use the coil overs i already have . my question is should i shorten my struts (fb) to the sane length as the original rx2 length or leave them rx7 fb length?the spring rate is 200 and the car is moderately lowered (performance low not dumped in the weeds low). Its a turbo car so not much more weight in the engine bay compared to stock . Not to be rude but I would like to find a solid answer not an opinion ,and what supports your answer .Or have you had this problem yourself . Suspension is a serious thing and I just want it right . Unfortunately a lot of people cheap out they're suspension by not using all the parts needed . They want a "sporty look" but dont want to pay for it ,I will buy or fabricate what i need and just want it right .thanks Matt
    Jan 2012
    Kitchener Ontario Canada
    23
    Re: mazda rx2 front suspension ?
    I have the exact same setup you have. Whats your question?
    I'm using Re-speed lower control arms with Miata ball joint, FB spindles/shock tubes, Re-speed "race" coilover kit, RX2 upper camber plates, 1" bump steer spacers.
    http://i256.photobucket.com/albums/hh19 ... pic037.jpg
    I haven't driven with this setup yet, but are you suggesting the shock bottems out and caused yours to bend? Because mine seems to have lots of travel, I wouldnt be able to bottem my shock out if I tried.
    Aug 2011
    norcal
    66
    thats odd ,my springs are shorter and my welded collars are 4" from the top of the shock body . I did find that i had no bump stops.My question is why did I bend a shock rod ?
    Jan 2012
    23
    Oh yeah, forgot to mention that I welded my collars really low on the shock tube so I can go very low, also in that picture my springs are 8in tall if I remember right. so they dont come close to the camber plate as it sits in that pic. If I fully compress the shock up until the swaybar/caster bar binds up the springs still arent touching the camber plate haha. Once the springs are threaded all the way to the top the car sits at a good ride height.
    I seem to have LOTS of shock travel, so I dont think your botteming out the shock at all. Maybe you bounced off a pot hole really hard or curbed it recently? Thats the only way I could see bending the shock.
    Jan 2012
    23
    Oh also I'm wondering what sort of camber you have with the FB spindles and camber plates?
    Again, my car is still on jackstands and I dont seem to have any camber at all...alomst positive camber actually. Which sucks cause I'm running massive rims up front and I'm going to need to run -3 or more to make them fit.
    Heres what I did:
    http://i256.photobucket.com/albums/hh19 ... pic032.jpg
    Heres my rim test fit:
    http://i256.photobucket.com/albums/hh19 ... pic025.jpg
    http://i256.photobucket.com/albums/hh19 ... pic023.jpg
    http://i256.photobucket.com/albums/hh19 ... pic022.jpg
    I roughly measured -3 camber in that picture and where I re-drilled the camber plates.
    Aug 2011
    norcal
    66
    if you want you should be able to put "Ground Control"( thats the brand) camber,caster plates in . I have a set I can check if they fit the rx2 strut tower .they are 4 hole and use a 1086 tociko strut .I don't want to modify my strut towers so i went with the re speed camber plates . Also the racing beat caster correction plates can be turned to give you camber ,but it will be fixed. Are those rx2 struts they look like it.I have a lot of different front end parts for rx so if you need any parts or help give me a holler .I remember hitting a massive pot hole so you are probably right on that part. Thanks for all the pics they are very helpful.
  1. In Need of After market front suspension for my 1973 808
    By Alberta808 in forum Mazda Garage
    Last Post: 01-14-2015, 06:56 AM
  2. Front suspension struts on ae72
    By zakte72 in forum Toyota Garage
    Last Post: 02-09-2014, 03:46 AM
  3. FS:Front Coilover Suspension and Rear AGX setup Celica Supra
    By TransAmBandit in forum Toyota Swap Meet
    Last Post: 09-14-2012, 08:18 PM
  4. Crown Front Suspension Part Number Help
    By mjacobs11 in forum Toyota Garage
    Last Post: 06-02-2012, 02:35 AM
  5. 4age engine, Parts, AE86 front suspension etc
    By jdoggmr2 in forum Toyota Swap Meet
    Last Post: 09-11-2010, 11:49 PM
