Results 1 to 5 of 5
Thread: 1jz ? w50 transmisson?
    Aug 2009
    ohio
    44
    I just bought a 1jz twin turbo. long block.. I heard it will bolt to a w50 transmission. Is that true? Because that's what I have and would make things a hell of a lot easier.
    Feb 2007
    SO-CAL
    270
    You'll need a 1jz bellhousing, but why you' want to use a W50 is beyond me. You'll want to get a R154 out of a 7MGTE supra. Then you'll never have to change it.
    Aug 2009
    ohio
    44
    if I find a r154 transmisson. will that bolt right up or do I still need a 1jz bell housing?
    Feb 2007
    SO-CAL
    270
    you're still going to need the bellhousing. Look on the supra/sc300 forums. You'll probably find one there. My friend got one from Toyota some how. I think he paid around 300 for it. I'm sure if you look on ebay or on the forums you'll find one cheaper.
    Aug 2009
    ohio
    44
    i just found one locally for 300 and it comes with the turbo rear end.. thanks guys .
  1. What should I do (engine/transmisson swap)??
    By jacbo in forum Mitsubishi Garage
    Last Post: 08-19-2009, 10:18 PM
