Results 1 to 4 of 4
Thread: Datsun 810 sedan rear strut assembly replacement
    Jan 2012
    South Dakota
    22
    Has anyone here ever replaced this rear shock strut assembly? If so, did any problems show up? Looks as if the biggest thing is removing the spring off the old shock and putting it on the new one.
    Any comments please.
    Feb 2007
    Huntsville, AL
    38
    Re: Datsun 810 sedan rear strut assembly replacement
    Changing the rear 810 shock is very straightforward. Much easier than changing out the front strut inserts. Only problem I can remember is that access to the nuts at the top of the strut assembly requires you to remove the rear panel in the trunk or you can pull the speakers from the rear deck panel as well.
    Just use a set of spring compressors to remove the springs. Harbor Freight sells them:
    http://www.harborfreight.com/macpherson ... -3980.html
    P.S. The four-door cars are "sedans". You have the two-door version or the "coupe".
    Jan 2012
    South Dakota
    22
    Thanks so much for the info Mr. Steve. That's just what I wanted to hear. People like you are what makes this forum great !!
    .... and OOPS, what was I thinking calling my 810 a sedan. :mrgreen:
    Will give this replacing job a go. Will be 80 yrs. old this June, so climbing around under my old cars gets a bit tough. :tu:
    Jan 2012
    South Dakota
    22
    Yea, got 'er done. Bought the low priced spring compressor from Harbor Frt. Now on to more tweeks. :tu:
  1. Replacement Ke70/te72 sedan oem brand new mudflaps
    By boblook in forum Toyota Swap Meet
    Last Post: 01-02-2015, 07:35 PM
  2. WTB 510 sedan rear seatbelts
    By myte_510 in forum Datsun/Nissan Swap Meet
    Last Post: 03-16-2012, 09:00 PM
  3. f/s: datsun b310 corner lens assembly
    By subuh_dinosor in forum Datsun/Nissan Swap Meet
    Last Post: 07-05-2011, 08:17 AM
  4. for sale: Datsun 280z front bumper assembly.
    By njccmd2002 in forum Datsun/Nissan Swap Meet
    Last Post: 01-15-2011, 12:22 PM
  5. JDM FEEL'S front+rear strut bars for 84-87 CIVIC/CRX SI
    By OldSchoolMugen in forum Honda Swap Meet
    Last Post: 07-04-2010, 05:58 PM
