Results 1 to 5 of 5
Thread: L2800 Tuning
    Oct 2009
    UK.
    224
    L2800 Tuning
    Hi All
    now i know this has been done to death on other forums but I'd be interested in views, opinions etc that you guys have on tuning a 2.8 Straight 6 NISSAN N/A engine........................... :P
    5,529
    Re: L2800 Tuning
    Can you please define "tuning"? That covers quite a lot of ground. :P
    Oct 2009
    UK.
    224
    Re: L2800 Tuning
    aaah yes it does. I would say tuning of NA and not going Turbo, stroker, inj etc. Part from the usual exhaust manifold stuff.
    Nov 2008
    Orange County
    248
    Re: L2800 Tuning
    ...I've learned a lot from this guy... Useful information on compression, heads and such... Explore around the site
    http://datsunzgarage.com/engine/index.htm
    Re: L2800 Tuning
    hi,
    well I agree with Dachshund to check that site (lots of good info), as for how much you can do I myself done some research and found that most non turbo applications can be in the 130 to 170 hp (over boring, etc)
    using L28 parts, as for doing something real good there is the option of using L20A head (I think the turbo head is more suited) on a L28 turbo block (before asking me check youtube for video of +9300 rpm at le mans ) he used L20 head (shorter cam range(profile) and smaller valves combined with L28 block to reach that RPM. some videos in youtube states that a japanese L28 N/A is 400 hp ( the head has been reworked and its single cam). to go down to the point, you can make a stroker 3.1L using LD28 crank. My own idea which I'm waiting to have the stuff to do it is this: L28 turbo block + L20a crank + L16 rods (as I remember) + L20ET head (modified as well using tig welding and valves from other nissan engines) + custom fuel injection (or use RB20E DE DET) systems + garret turbo (didn't make research on the best match yet) + and as for pistons I'm thinking forged aluminum with an available type of pins, so large displacement with shorter crank hills added to very small chamber with charged air and you get a high revving engine, note that the L20a crank journal is the same width as L28 if not then my bad, but I do remember reading about L20 or LD20 with same crank journal size.
  1. Southern California early Z tuning shops
    By Aeropooch in forum Datsun/Nissan Garage
    Last Post: 12-01-2013, 06:38 AM
  2. Super power tuning my Z600
    By 2stroketurbo in forum Honda Garage
    Last Post: 03-04-2013, 01:03 AM
  3. Tuning shops/J tin attractions in Los Angeles
    By oldisgold in forum Off-Topic
    Last Post: 04-26-2012, 01:01 AM
  4. tuning solex 40 twinsides properly...
    By sprikitik in forum Mitsubishi Garage
    Last Post: 07-29-2011, 01:40 PM
  5. tuning the twin SU carbs on the L20??
    Last Post: 07-24-2011, 07:58 AM
