Results 1 to 10 of 14
Thread: Problem with forum
    Nov 2007
    Finland, Scandinavia
    34
    Problem with forum
    Hi there,
    Wasn't 100% sure if this is the correct location, but I need to ask if you have any solution for my problem.
    I enter the JNC forum from my bookmarks. (http://www.japanesenostalgiccar.com/forum/)
    Usually, I'm logged out whether or not I have last time chosen "keep me always logged in" (or whatever it says). So I have to log in. It may succeed or not, usually it takes two attepts to get in.
    Aftter logging in I go to Toyota Garage. I see that there are new posts since my last visit and I shift-click the icon to open the threads (into new tabs). I usually open several threads and go to read the first opened. It looks OK and shows me the thread starting from the first not read message. OK, but when I open the next tab, the message says (there are no unread messages). I need to open the full thread and search for the first unread post MANUALLY. Really frustrating! This happens againg and again until I have gone through all the opened threads.
    I'm using several forums daily and no other forum has this kind of problems. I use YaBB forums and SMF forums, but I think this is the only phpBB I'm trying to use. I don't think it has anything to do with cookies since all the other forums work fine. Please tell me what's wrong! Thanks!
    Dec 2008
    Malaysia
    320
    Well, my problem is quite similar to yours I guess.
    Since I'm accessing the forum using the computer at home, I chose the "keep me always logged in" option. If not, every time I log in, I need to log in again! Meaning I have to log in twice! Once successfully logged in the second time, the forum says there are no new posts. It seems that I was logged out as soon as I logged in the first time. It's like logging in, logging out and logging in again within seconds, so searching for the new posts feature returns zero result!
    Jul 2007
    S.W. Missouri
    162
    I have the same problem...I usually log in by going thru the "log in to check messages" tab...It seems to keep it from erasing the new posts.
    Feb 2007
    The OC
    513
    Re: Problem with forum
    Quote Originally Posted by cman
    Hi there,
    Cman,
    I have the same problem as edz280zx and SharmCos, and your problem sounds similar to ours. Like edz280zx mentioned, I also always log in by the "Log in to Check Messages" option and things are okay - it's a bit inconveniant, but seems to work. I never log in using the "Log In" option located at the top and bottom of the screen. I've experienced this problem ever since the forum went online and have addressed the situation with Ben and Dan but at that time there didn't seem to be a solution (@ the time, they found solutions in reference to cookies, but that didn't seem to help any). I've been on other phpBB forums and have never encountered this problem.
    Try logging on with the "Log in to Check Messages" option and see if that doesn't solve your problems.
    p.s. The "keep logged in" feature also seems to never have worked properly, at least for me it hasn't... :cry:
    Mar 2008
    Salem, OR
    98
    I use Firefox as my browser, I always start at the main page and I haven't had any problems yet. Logs me in automatically and works as it should.
    Feb 2007
    The OC
    513
    Quote Originally Posted by Tyson
    Ah, so it must be an IE issue... I love Microsoft :x
    Dec 2008
    Malaysia
    320
    The automatic log in works OK for me. The problem only appears when I log out i.e licking Log Out rather just close the tab/window.
    I only use Google Chrome. Haven't tested with any other browsers.
    Jan 2007
    3,108
    We're using phpbb software and unfortunately know nothing about its inner workings.... If someone does, any help would be greatly appreciated!
    I think we're overdue for an upgrade but I'm afraid it might mess things up. When we have some time we'll upgrade. Firefox seems to be the best hassle-free browser to use with this site (not to mention many others). Sorry I don't have a better answer for you...
    5,527
    x2 8)
    IE hates this website, along with 3-4 others I go to a lot, so I just deleted it altogether. :tu:
    Oct 2008
    Jefferson City, MO
    23
    Do you have the "accept cookies" option chosen? Does it do it for other sites too or just this one?
  1. Register problem Admin help please
    By butterz31 in forum Off-Topic
    Last Post: 01-01-2013, 05:17 PM
  2. gearbox problem
    By datsun200l in forum Datsun/Nissan Garage
    Last Post: 02-08-2012, 12:31 PM
  3. rt135 od problem
    By oldskl in forum Toyota Garage
    Last Post: 10-13-2011, 09:34 PM
  4. HID conversion problem
    Last Post: 09-10-2011, 03:15 AM
  5. Idling problem
    By stefaantje in forum Toyota Garage
    Last Post: 02-01-2011, 12:50 PM
