Results 1 to 9 of 9
Thread: Wheel gurus I need your help. Postive offset 5 stud wheels.
    Jun 2009
    Melbourne, Australia
    802
    Scenario:
    inherited this (second picture isn't my car, it's another that is apparently in the same city as me and even the same club but I haven't found the owner yet). V8 blah blah blah. Has the very unhelpful pcd of 5x5 or 5x127. Because it has the engineering marvel of De Dion rear suspension and a McPherson strut front with an elbow, it has factory 14in wheels with a positive offset.
    I coughed up and bought some okayish looking Rostyles for it off a p5b that are 15x5 with a +33mm offset, which is apparently boarderline for use. Apparently if you go too close to neutral offset it upsets the handling. Performance Wheels in Australia sell a minilite copy that is I think a +24 offset which is about the only wheel I can find in alloy that comes in that stud pattern - but the offset is wrong.
    I need to find something in a 5 stud pattern (I will either get the wheel hubs changed or the wheels re-drilled) in a 15x5 or 15x6 wheel in a highish offset that looks period (ie 60s/70's) and is alloy. I could get the Rostyles re-finished but they weigh a ton as they are literally solid steel.
    Suggestions? I like some of the 60's American Racing wheels or even Halibrand kidney wheels, but I can't find anything in a positive offset.
    Jan 2010
    Australia
    322
    Re: Wheel gurus I need your help. Postive offset 5 stud whee
    The superlites go up to +33 on a 15x6 with a PCD up to 140.. Whats the stock offset and rim width?
    Jensen Interceptor rims look good on them, might be a bit hard to find though..
    Have you tried on the rostyles yet?
    Jun 2009
    802
    timmeh!
    Yeah, but if I want superlites in the original PCD they only make them in a +24 offset, which is apparently a big no no. Makes the car feel unbalanced or something something. There's also a body weld inside the rear arch that apparently you have to cut away and weld up again if you start moving the tyre too far inside the rear wheel arch. I think this and the funky suspension is why they have a positive offset (which is kinda weird for the era).
    the steel wheels that are 14" = total width of 166mm, backspace of 132mm and an offset of 49mm.
    I don't like the Jensen wheels either, plus they'd be pricey here in Aus I think.
    p6b's look like this with p5b rostyles (I can't be bothered finding a proper set of p6b rostyles as they are a 14in)
    I think I'm going to have to keep looking...
    Jan 2010
    Australia
    322
    Get flares. Problem solved!
    or black steelies like that blue one on retro rides..
    Saying that, not much goes with brown :lol:
    Jun 2009
    802
    I can't put flares on it, my family will murder me in my sleep.
    With the blue car, Sowen had to cut the unibody a lot and get those steel wheels modified and at the end of the day, they are steel still so they still weigh a fair bit!
    Jan 2010
    Australia
    322
    Hmm so MX5 NA rims look kinda retro? 14x5.5 +45 so a good width and offset for you - just need to change wheel or stud pattern. They weigh just over 5kg a rim. There's a set on eBay for $99 atm in VIC..
    I'm sure you could polish up the lip and repaint the spokes and they'd look ok
    Jun 2009
    802
    hmmmm, that's not such a bad idea! I wonder if you can redrill them to a 5 stud...
    From memory they are apparently stupidly light too.
    Jan 2010
    Australia
    322
    Quote Originally Posted by timmy201
    Jun 2009
    802
    D'oh! I should read things a bit better eh?
    Pity they are 14in though. Someone on Auszoku has popped up with some Wantanabes that may fit the bill in a 15. God I love the internet...
  1. Mazda wheel bolt to stud conversion/longer bolts
    By Cody mackay92 in forum Mazda Garage
    Last Post: 01-10-2013, 12:34 AM
  2. Re-Drilling wheels from 4x114.3 to 4x110 Stud Pattern?
    By Dazz in forum Resto Tips, Wheels & Other Goodies
    Last Post: 12-10-2011, 11:22 PM
  3. ID this wheel offset plz...
    By ericbauer in forum Datsun/Nissan Garage
    Last Post: 07-29-2011, 02:41 AM
  4. How to change Wheel stud bolts(replacing a longer stud)
    By Daynger in forum Resto Tips, Wheels & Other Goodies
    Last Post: 11-07-2010, 09:12 PM
  5. Wheel stud part numbers, KE30/TE31
    By Hoova in forum Toyota Garage
    Last Post: 02-05-2010, 11:04 PM
