Results 1 to 7 of 7
Thread: Powder coating question
    Sep 2010
    Magna, UT
    689
    For powder coating, can you use a normal paint spray gun?
    Apr 2011
    United Arab Emirates, Dubai
    420
    Re: Powder coating question
    A powder coating gun is usually an electrostatic gun which positively charges the powder as it sprays it.
    Sorry buddy, I do not think a normal spray gun would cut it.
    Sep 2010
    Magna, UT
    689
    K. That is fine with me. I was pretty sure that was the case, but wanted to verify before spending money Still doing research on this whole topic.
    Apr 2011
    420
    If you are attempting to powder coat something yourself the easy way is to pre-heat the metal component then put it in to a tub of the powder. The powder sticks to it and melts a little then you cook it a little longer in your oven to cure it leaving a smooth finish (in theory).
    Problem with this method is that the coating is always thicker and usually of uneven thickness as during the curing process the melted powder will normally fall because of ye olde gravity.
    I messed around with this method when I made stuff at school with varying degrees of success.
    Sometimes got little pin-hole air bubbles on the surface etc.
    Not sure if this is relevant or helpful but.....
    Northern California
    635
    Eastwood had a fairly good kit that you could buy for cheap. Just need an oven to bake your parts.
    Sep 2010
    Magna, UT
    689
    Thanks for the input.
    My current plan is to buy a craftsman powder gun. They are cheap and hopefully will work for the little I will be using it now. The dip method seems interesting, but wouldn't you need alot of powder if the items were bigger? I am hoping to powder most of my suspension pieces before putting new bushings in, just so they will be clean and look good.
    On the oven, I am making a make shift setup now, which consists of a counter burner and making a metal enclosure. Found some of these setups online and while they are not big and nice, they should serve my purpose well. In the next year or 2 I willl replace that setup with the crappy oven in the house when the women decides she can't handle using it anymore lol.
    Feb 2012
    San Jose, CA
    154
    My teammate runs his own powder coating business and can give you his info if you need it. I can have him hook you up with good pricing if need be...sadly, he lives in the bay area...
  1. Chassis Saver - protective coating
    By Drive510 in forum Resto Tips, Wheels & Other Goodies
    Last Post: 04-11-2012, 02:05 AM
  2. 4ag-e t-50 question
    By InZanity in forum Toyota Garage
    Last Post: 06-03-2010, 05:44 AM
  3. Powder Coating Examples
    By redvalkyrie in forum General Discussion, JNC News & FAQ
    Last Post: 05-18-2010, 03:15 PM
  4. hid question
    By blitzk08 in forum Resto Tips, Wheels & Other Goodies
    Last Post: 02-14-2010, 03:01 AM
  5. 2TG question
    By in forum Toyota Garage
    Last Post: 10-22-2009, 08:11 AM
