Results 1 to 7 of 7
Thread: Anyone ever rebuilt a brake booster?
    Sep 2010
    Magna, UT
    689
    I have an 80 Corolla that I am replacing the MC on. After some thought I would also like to rebuild the brake booster if possible and feasible. Anyone have any experience with this? Is it a good choice to rebuild, or just buy one already rebuilt?
    Sep 2010
    Magna, UT
    689
    Re: Anyone ever rebuilt a brake booster?
    Ah. K. Well, I am on the fence about getting it rebuilt anyway. There is a rebuilt unit on ebay that I could try. Don't need to replace it, just would like to since I know it's not doing shit.
    I probably wont be worrying about it too much if I could find a setup just to remove the booster, but that looks like a whole new challenge.
    Sep 2011
    Lyons, KS USA
    223
    Quote Originally Posted by rkkopra73
    Brake boosters are on every single car since their inception for a very good reason.
    unless of course the vehicle didnt have "power brakes" :wink:
    anyways.... www.rockauto.com a1 cardone part number 53-5101 $92.79 + $20 core
    Sep 2010
    Magna, UT
    689
    They run the same price at auto zone and cheaper on ebay. So, I do know it's still an option. It just would have been nice to try and rebuild it myself.
    The thing is, on our cars, most of the boosters are not really doing anymore due to wear and tear. I did enough research to know that when the booster breaks, it just means it quits assisting you.
    Now for me I want have been considering removing the booster for more space on the exhaust side when I go turbo Plus, this is not a DD or show car. It will occassionally get driven on the road and mostly track related things when done, so the booster is more of an issue then a help. Plus, since I have driven this car I dont think the booster is doing much, besides making it hard to predict brake feel
    Sep 2011
    Lyons, KS USA
    223
    when the diaphragm on the booster blows you will have a massive vacuum leak and a lot of the time you will hear a hiss and feel your foot slowly go to the floor enough that you have to repump the brake pedal to stop the vehicle. if neither of these is going on i am going to venture to say there is nothing wrong with your brake booster at all
    Sep 2010
    Magna, UT
    689
    That could be the case, but there is a valve going from my intake to the booster that I assume could prevent a leak. Never looked into it though. I just assume.
    I thought a leaky MC is the only thing that would cause you to have to pump the brakes since the booster has no fluid running through it? Judging by the booster diagram it has a rod from the pedal the booster which then is pressed against the rod that pushes into the MC.
    Either way, I wont be trying to rebuild. I cleaned up my stock one and I will probably be moving to a tercel booster and MC when I try to go turbo just to make more bay room.
    Sep 2011
    Lyons, KS USA
    223
    Quote Originally Posted by UtahSleeper
    that valve is the vacuum check valve. like a 3 dollar item at the parts house. most of the time when the mc goes bad the pedal will stay on the floor and not return without using your toes to pull it back up. not sure if others have experienced it but i have in a gm pickup where the booster went bad and i had to pump the pedal several times and the master cylinder was still good. most braking systems are remotely alike so i can compare it :lol:
  1. Deleting Brake Booster--How bad is the Increase in Effort?
    By redvalkyrie in forum General Discussion, JNC News & FAQ
    Last Post: 08-14-2014, 08:16 AM
  2. WTB: MX13 (1973 Corona MkII) Brake Vacuum Booster
    By 3f05q in forum Toyota Swap Meet
    Last Post: 04-08-2011, 07:32 PM
  3. Removing Brake booster Carolla SR5???
    By corolla 1975 SR5 in forum Toyota Garage
    Last Post: 02-26-2011, 08:09 AM
  4. Brake Booster spacer???
    Last Post: 12-05-2010, 10:21 AM
  5. Power brake booster on a 68 Crown?
    By davidgsus in forum Toyota Garage
    Last Post: 08-14-2010, 07:43 PM
