Results 1 to 2 of 2
Thread: Re-Drilling wheels from 4x114.3 to 4x110 Stud Pattern?
    Oct 2009
    Australia
    46
    I've been looking for some 14x7" Enkei Cross Fevers for my RX-4, which has a 4x110 stud pattern, and the few wheels I have found are always 4x114.3.
    There appears to be plenty of meat to do this, I assume the fill the existing hole with some kind of bung and then re-drill the holes to the new stud pattern.
    Has anyone had their wheels modified from one stud pattern to another, and does anyone know a good place to get this done in Sydney, Australia?
    Mar 2009
    Australia
    627
    Re: Re-Drilling wheels from 4x114.3 to 4x110 Stud Pattern?
    I'm going to have this done to my wat's.$40 a wheel down in vic. Neales do it as well in Sydney for 75 a rim. They redrill and use an offset plug with a new hole position.114 to 110 is fine, anything outside of that range will cause you trouble. If there is lots of metal like you said you should be fine.
  1. Wheel gurus I need your help. Postive offset 5 stud wheels.
    By ewokracing in forum Resto Tips, Wheels & Other Goodies
    Last Post: 02-01-2012, 10:30 AM
  2. WTB: SSR Longchamp XR4 - 4x110 or 4x114.3
    By maz72 in forum Wheels Swap Meet
    Last Post: 07-14-2011, 09:39 PM
  3. Replies: 2
    Last Post: 05-20-2011, 03:51 AM
  4. Enkei 92 15X7 PCD 4X110 Mazda bolt pattern 7 offset
    By FjFairlady in forum Wheels Swap Meet
    Last Post: 03-30-2011, 03:56 PM
  5. How to change Wheel stud bolts(replacing a longer stud)
    By Daynger in forum Resto Tips, Wheels & Other Goodies
    Last Post: 11-07-2010, 09:12 PM
