Results 1 to 8 of 8
Thread: Audio setups and still keep it classy
    Aug 2011
    Atlanta,GA
    34
    I drive my car alot, and im wanting to upgrade the radio but have a hideaway headunit. Anyone ever try one of the vintage hidden radios? Looking for ideas..
    Aug 2011
    Adelaide, Australia
    108
    Re: Audio setups and still keep it classy
    Ive been thinking about it a lot and probably the best idia i had so far is to use radio with detachable faceplate hide main unit where you like (been thinking under seat) then solder extra long wires to connectors from main unit to faceplate and put it where you would like it (i thought roof mounted next to rearview mirror) as wires and speakers much berret just run RCAs for amp, so it totaly independent from original(most likely crapy) wiring. I have head unit + 2 amps 4 chanel and mono for Sub.
    Aug 2011
    Atlanta,GA
    34
    Quote Originally Posted by Chuxa
    considering a glove box mount for mine
    Aug 2011
    Adelaide, Australia
    108
    Quote Originally Posted by jitb
    Glove box is good but i prefere to see whats playing and i like to be able to controll it unless you have a remotecontrol
    Jun 2008
    Tampa FL
    125
    I have one of these that I just hook up my MP3 player to, I find a good spot to put this in my car and it sounds great!
    http://www.amazon.com/Lifetrons-DrumBas ... B005KIIOSM
    Jul 2009
    New South Fails, Australia
    225
    I just put a Panasonic head deck in where my factory AM/FM radio was and glued a section of black plastic over the hole where the factory tape deck was.
    Looks quite good, a little out of place but it's not a flashy head deck so it works quite well.
    Speakers are a pair of factory VR Commodore Eurovox jobbies in the parcel shelf.
    Aug 2011
    Atlanta,GA
    34
    Quote Originally Posted by RX-2Fan
    how does that thing sound seems interesting.
    Jun 2008
    Tampa FL
    125
    When I first used it I was working on something in my garage, I hooked it up to my phone and put on a pandora station to test it. I had the volume louder than the stereo that I have in my garage and it sounded just as clear as the music on the stereo, with decent bass. I was actually suprised at how well it sounds. Then I put it in my car and it didn't sound as clear as it did in the garage, but then I started moving it around different spots in my car until I found a spot where it sounded excellent. If you have a car that you don't want to cut up the originality on then I highly recommend this.
  1. Possible coilover setups for 81 corona
    By renchi_akuma in forum Toyota Garage
    Last Post: 02-25-2015, 04:52 AM
  2. post your ignition setups!
    Last Post: 12-01-2011, 01:06 PM
  3. Youtube vid: Retro car audio test - Pioneer KP-707G
    By Orion in forum Resto Tips, Wheels & Other Goodies
    Last Post: 06-22-2011, 07:03 PM
  4. Clutch/Flywheel setups L6 engines (Hako)
    Last Post: 03-07-2011, 08:22 AM
  5. j-tin audio
    By arsonist63086 in forum Resto Tips, Wheels & Other Goodies
    Last Post: 06-25-2010, 05:44 AM
