Results 1 to 8 of 8
Thread: Winter projects?
    Aug 2010
    WV
    109
    Winter projects?
    Today will be the last day this year that I drive the fb, so I have been sitting here thinking of all the things I need to tear into while it is garaged and the white stuff is flying outside.. I'll be replacing wheel bearings and ball joints, installing poly bushings, hopefully installing my kaaz 1.5 way lsd, and patiently saving my lunch money for a new set of Hayashi Streets. Who else has big plans for their J-tin as winter offers some downtime? I used to hate that the weather and salt on the roads around here almost forces me to put my tin away, but now I'm starting to appreciate the time it allows for catching up on maintenance and upgrades. Also, it is nice to drive a fuel injected vehicle with a face-melting heater when its 12 degrees and windy..
    Feb 2010
    Cleveland, Ohio
    1,608
    Re: Winter projects?
    I'm going to be doing some basic maintenance and tidying up the paintwork on the FC, and collecting parts for a full resto on my SA.
    Nov 2008
    Orange County
    248
    My JNCs seem to have lapsed into reliability so... This:
    Old picture of the car, but it hasn't changed looks wise in a while... I'm actually fairly certain that they left the factory with just as many dents, faults, and paint chips :lol: The whole car actually may have been a designated fault.
    But, I now have fuel pressure and ignition, every electrical component in the car works (!), and it'll start and run if I give it some throttle whilst turning the key, so it may only be an AFM adjustment away from running properly... Though I now may have detected head problems :? Luckily, thing has the same L-Jet system as the 280z and Z31, so that makes things more intuitive for me.
    Once that's sorted, it'll be on to the brakes and clutch
    Mar 2010
    SF Bay Area, CA
    351
    I was going to use winter time to replace a section of my zeds frame rail and pass floor...however there is an event on new years day...so thats getting pushed back to winter/spring.. :mrgreen:
    Sep 2010
    Magna, UT
    689
    My plan is to finish my door panels and gather parts to remove my brake booster and replace the master cylinder. May also replace the gaskets and crap on my rear end, or replace the rear end.
    Feb 2007
    Napa Ca
    209
    Quote Originally Posted by Dachshund
    Oh man, you are a glutton for punishment aren't you. :wink: Good luck with that.
    I've got a few things planned for my roadster, fixing the bent shift fork so I can have 1-2 gears back, replacing the axles with some new chromolly ones (a much needed upgrade there, broken axles suck.) I'll also be replacing a couple of side bearings in the rear diff so it will quit howling like its got straight cut gears. There are a few other issues that I'll be addressing while I'm in there as well.
    Will
    Feb 2007
    Canada
    179
    The convertible TR7s were much better built than the earlier coupes. If yours has fuel injection then it is one of last built at the Rover plant. Best quality. I quite like TR7s myself but never owned one. Did own a Spitfire for a while - great fun.
    I bought a little Nissan Micra as my winter beater. It needs a little love but fun car.
    Aug 2008
    Atl GA
    376
    This is my winter project!
    A 1JZGTE RA64
  1. Some JNC Winter Fun with my C32 Laurel
    By 260z in forum Datsun/Nissan Garage
    Last Post: 12-28-2014, 06:24 PM
  2. bonvos winter warrior
    By bonvo in forum Subaru Garage
    Last Post: 05-29-2013, 04:02 AM
  3. Itīs getting cold outside, winter pictures...
    By ChristophMA61 in forum Toyota Garage
    Last Post: 12-02-2010, 09:45 PM
  4. Last pic before winter storage.
    By Celicaholic in forum General Discussion, JNC News & FAQ
    Last Post: 11-11-2009, 06:44 AM
  5. ongoing projects: 1976 Colt Galant-- 4-door and 2-door
    By pedro168 in forum Mitsubishi Garage
    Last Post: 07-16-2009, 01:03 PM
