Results 1 to 10 of 16
Thread: Hi from the UK, a newbie with a modded Z600 Coupe
    Jul 2009
    Essex, UK
    37
    Hi all,
    I'm a relative newbie here, have just bought a UK spec 72 Z600 GT Coupe, which has been lightly modded by a guy about 5 years ago.
    It has been debumpered, and repainted in black with blue detailing. Steel wide arches and a Fibreglass front air dam. Front indicators are Frenched in Mk1 Escort Ford items as are the rear lights which are mk1 Escort van, Frenched in vertically, which i definately plan to get rid of as they are terrible. The rear plate has been moved to the rear centre bumper slot which looks ok.
    The car has 10*6 Starmag wheels like they used on old mini's, but I plan to replace them with some 13*6 Minilights or RX7 wheels if i can find them. I've also discovered that ATV's use the same stud pattern, so some of the aftermarket alloys for them may work out.
    Here are a few pics from the auction where i bought it. It will be tidied up stock rear lights reinstated and repainted in silver with darker silver striping as they used to be.
    Dec 2008
    Malaysia
    320
    Hello & welcome mate.
    Cool car. From which auction did you but it 'cos I remember seeing those pics before, most probably on this forum!
    I have a few pairs of fender mirrors from Honda Z coming soon. Some are from this model I think
    Jul 2009
    Essex, UK
    37
    It was on ebay a few weeks ago. It was built by a guy in Scotland (edinburgh i think), about 5-6 years ago, he took 4 years to do it, but bare metalled the car, did the FG work and painted it himself.
    The black is pretty good, but alas the lacquer that was used on the blue is cracked and worn.
    I don't like the rear end much (lights mainly), so am hoping that i can get it stripped back, stock rear lights or similar put back in and repainted in a mid silver with darker silver detailing. Let me know if you get those mirrors as the current one on the drivers side is rubbish.
    I'm still looking for wheels and a few have come up but i think it may well end up cheaper to get some new compomotive ML's / revolution / minilites etc made for it in the UK. I did think about trying to get the rear bumpers back on but these are difficult to find and the body has been cut about too much.
    The build spec says the engine was rebuilt at the time of the paint and has a longer duration cam from an N600. As all UK cars were the 45bhp 599cc models is this possible, were the cams different?
    Mar 2009
    washington
    74
    love the front end.
    Aug 2007
    Leeds in the UK
    230
    loving it and welcome from another uk resident :tu: :tu:
    Jan 2008
    Melbourne, Aust.
    87
    Very cool!
    I think UK only got Z in orange.
    Fitting original tail-lamps either side of that wide number-plate might be tight. Hope you don't find too much filler when you go for it.
    I think the earliest 600's had a bit more power, sacrificed for more torque in later models... which might have made them faster?
    Jul 2009
    Essex, UK
    37
    Yes as far as I can tell they were all orange with a black stripe up the side, this was rebuilt about 5-6 years ago.
    The whole rear light panel looks to have been remade and the form is Fibreglass, so it will need to be redone to take the lights. The reg plate has been mounted where the rear bumper used to go so I'm hoping the lights will still fit, if not I'll have to get a smaller reg plate made up or a square one and mount it more like the US or OZ cars. I notice they are different rear ends, with the US cars having the plate mounted quite high, I've seen a UK car done the same and it looks a bit odd with such a large reg plate, the Oz car that I saw had a smaller plate mounted slightly lower on the back with a light unit that said HONDA on it instead of a black board with the lights above or either side of the plate.
    It's proving quite hard to find decent pics of the rear of these things as most people only take the front.
    Jan 2008
    Melbourne, Aust.
    87
    Just looks a little higher than the bumper level.
    They are prone to rusting around the tail-lights & behind the wheels.
    Australian plates are about at inch wider than US/Japanese plates so ours didn't fit in the rear recess, resulting in pretty unfortunate arrangements.
    That improved slightly when the rear was re-styled for the water-cooled Z post '72, putting the plate below/between bumperettes.
    Jul 2009
    Essex, UK
    37
    Here is a better pic of the rear end, could some one tell me wether they think the stock rear lights would fit around the plate. I expect them to be slightly higher on the body so will be either side and slightly above the current plate.
    The plate drops down with the spare tyre cover at the moment, you can see the split line in the picture to the LHS of the plate.
    Jan 2008
    Melbourne, Aust.
    87
    Didn't have any problems finding rear photos
    There's only 44 cm between the rear lights to fit the number plate.
    The recess intended for the plate was only about 34 cm wide at the bottom so most markets added a plate over the top like this to fit bigger plates & additional plate lamps. I think you'd have to move the plate down a little otherwise so it was no higher than the bumpers/spare wheel access.
    & the Water-cooled rear, spare accessed from inside.
  1. [wtb] Honda Z600 coupé fuel gauge sending unit
    By pierren600 in forum Honda Swap Meet
    Last Post: 12-30-2012, 07:08 PM
  2. WTB Honda Z600 Coupe Roof
    By vwdmc16 in forum Honda Swap Meet
    Last Post: 09-07-2011, 03:41 PM
  3. Replies: 2
    Last Post: 07-27-2010, 04:44 PM
  4. NC/MD: Modded 1985 King Cab ST Z24 Part-Out
    By 720ST in forum Datsun/Nissan Swap Meet
    Last Post: 02-19-2010, 11:53 PM
  5. Replies: 9
    Last Post: 01-21-2010, 10:47 PM
