Results 1 to 2 of 2
Thread: motorcycle carburetors on civic 1200 ???
    Oct 2011
    Belgium Europe
    I am thinking on adapting a set of motorcycle carburetors on a 1200cc Honda civic 1978.
    in stead of using a set of RS carburetors, I was thinking of customizing 4 CBR600 carburetors...
    somebody has experience with this?.??
    or off course other types that are useable???
    Kind regards
    Oct 2009
    Re: motorcycle carburetors on civic 1200 ???
    Referring RS carbs I suppose you mean the twincarbs fitted to the RS Civic : these were Kei-hin I think and fairly similar to motorcycle carbs.
    I had a Coupe7 which I just bolted on a set of 4 from a coupe9 and changed the camshaft to the 9 profile. The carbs all looked the same type and similar to the ones on the RS Civic and the S-600 / S-800, being CV type they are self balancing at higher throttle settings so if you are using similar carbs putting 4 on a Civic should be quite easy. Its worth changing the Cam to the RS profile and getting a 4:2:1 exhaust system like the RS had too. I did the RS conversion to my 1330cc 1980 Civic by bolting on the twincarbs and manifolds from a 1200 RS engine and it worked great. Wish I'd swapped back the carbs when I sold it because of the Civics sold here the hottest was the S version and that basically meant it came with a Sunroof (the engine was no different).
  1. My Civic 1200 project.
    By ColoradoKP in forum Honda Garage
    Last Post: 09-09-2014, 07:35 PM
  2. Hilda 77 civic 1200
    By nsanethelane in forum Introduce Yourself
    Last Post: 05-27-2013, 07:50 AM
  3. My 78 Civic 1200
    By Highway_Dancer in forum Honda Garage
    Last Post: 07-01-2012, 01:05 PM
  4. my 78 civic 1200
    By loa706 in forum Honda Garage
    Last Post: 07-24-2011, 10:18 PM
  5. Replies: 22
    Last Post: 07-09-2011, 08:49 PM
