Results 1 to 4 of 4
Thread: Does anyone know if these are legit multi piece wheels
    Jul 2011
    IN/IL boarder
    48
    Potenza Mesh wheels. 14x6 i was looking all over the wheel to look for multi piece evidence, and i found a seam, that looks like it's welded, where the face connects to the barrel, but idk where else to look on the wheel. PLEASE HELP!!
    Sep 2010
    Albuquerque NM
    240
    Re: Does anyone know if these are legit multi piece wheels
    Generally, with a 2 piece wheel, the face will be bolted onto the barrel. There will be an obvious seam, and real bolts.
    With 3 piece, the face will be bolted and if you pull the tire off, you should see another seem right around where the face bolts up.
    What you have looks like it could be similar to SSRs. They're 3 piece, but the barrels are welded at the same...so people consider them 2 piece.
    Oct 2009
    westminster
    31
    the welds will always be on the backside. That one bolt off and take a look inside the hole. Check to see if you can see layers. The layers are the pieces that makes up the wheel. what are your plans if they are 3pc?
    Jul 2011
    IN/IL boarder
    48
    if i keep them, i'll probably flip the faces, if thats possible, it'd reverse the offset. i just had the tires off when i put new ones on, and i didnt even think to look :/
  1. List true 3 piece wheels here!
    By oldisgold in forum Resto Tips, Wheels & Other Goodies
    Last Post: 06-16-2014, 02:40 PM
  2. Hayashi Command 3 piece wheels 14x6 5x114.3
    By robakun in forum Wheels Swap Meet
    Last Post: 02-17-2013, 01:26 AM
  3. FS: Southern Ways Epsilon 3 Piece Staggered 15x7 15x8 Wheels
    By greggearhead in forum Wheels Swap Meet
    Last Post: 03-14-2011, 04:43 PM
  4. WTB: *PAIR* of 14" Equip 01 1 piece wheels-
    By Stationwagonguy in forum Wheels Swap Meet
    Last Post: 02-15-2011, 02:32 AM
  5. New 17" CCW Classic 3-piece Wheels with brand new tires
    By 280zForce in forum Wheels Swap Meet
    Last Post: 09-27-2010, 02:27 AM
