Results 1 to 3 of 3
Thread: Weber triple linkage problem. WTF is this called??
    Jul 2010
    Litchfield Park ARIDzona
    382
    so i cannot find this piece in the size i need anywhere, BUT its probably cause I'm calling it the wrong thing. I need it in 3/8"
    any idea what the technical name is for it? or where i can get a new one? my carbs aren't going to be up and running right till i get this piece, and my synchrometer..
    BY the way, i stole this pic from you Kev.. its the ONLY one i could find hope you don't mind ..
    PLEASE someone chime in or throw me a link.
    Thanks guys.
    Feb 2007
    Los Angeles
    14
    Re: Weber triple linkage problem. WTF is this called??
    Might try something like this.
    http://www.hrpracing.com/ViewProduct.as ... 4&pIndex=0
    Try searching for throttle arm, Pierce Manifolds might have the correct part as well. Might take a phone call if it is not listed on their web site.
    Is the one on the car now for a 10mm shaft? I am looking for one of those.
    Chris
    Jul 2010
    382
    i will check it when i get back over there, I'm thinking its for a 9mm shaft, but if its 10 i will let you know
    I've emailed pierce manifolds, but their customer service through email is pretty fail. i usually have to contact the owner personally to get the answers i need.
    i like the throttle arm you posted, but i don't have a swivel so i really just wanted the one that has the slotted channel for the cable to sit in like the ones that most modern throttle bodies have or basically just like the one in the picture
  1. (SOLD) Weber 40DCOE triple side draft carbs with cannon
    By skyrine in forum Datsun/Nissan Swap Meet
    Last Post: 06-06-2014, 04:47 AM
  2. Replies: 0
    Last Post: 12-05-2013, 10:45 PM
  3. how to remove hood cowl (think thats what its called
    By jdmeg21 in forum Toyota Garage
    Last Post: 12-13-2012, 07:13 PM
  4. weber 32/36 install problem help...
    By 76 TE31 in forum Toyota Garage
    Last Post: 11-01-2011, 02:50 AM
  5. f/s Triple Weber 40 DCOE
    By ctcurnes in forum Datsun/Nissan Swap Meet
    Last Post: 04-22-2010, 02:04 AM
