Results 1 to 10 of 18
Thread: lowering a car that has leaf springs....?
    Oct 2011
    Pomona, Southern California
    18
    I have a stock 85 Suzuki Cultus/Chevy Sprint.
    [[pictured here]] http://japanesenostalgiccar.com/foru...p?f=15&t=16207
    I have never lowered a car that has leaf springs before
    and I'm not sure on what to do.
    Should i flip the leaf springs?
    or put in lowering blocks??
    Have any ideas on what i should or should not do?
    Oct 2009
    westminster
    31
    Re: lowering a car that has leaf springs....?
    Flip the leaf works but limits the quality of the ride, remove one or a few of the helper leaf, de-ached (mordrop). Blocks are the worst way to lower leaf because it will set the pad where the leaf rest on closer to the ground which maybe or will get snag on road pot holes or bumps.
    Sep 2010
    Albuquerque NM
    240
    Quote Originally Posted by dimsum
    ...remove one or a few of the helper leaf, ...
    this. :tu:
    Sep 2009
    Los Angeles
    161
    Rearching the leaf is probably best. Removing a leaf is not a good idea because it reduces load capacity and spring rate. I believe, leaf springs can also have the eyes curled the other way. If you use blocks, cut off excess threads on the U-bolts which are usually universal length.
    Sep 2011
    Lyons, KS USA
    223
    flip the u bolt and spring pad. do not flip the springs just the pad and u bolt and rearch a bit. you could also flip the shackle if its a drop down instead of hinge and make it a hinge style like the 73-87 chevy pickups are stock. i personally hate blocks but then again the only time i play with leaf springs is lifting pickups :wink:
    Atlanta, GA
    213
    Goodness gracious, what's happened here!!!
    Lolol.
    Man I took all helper leafs out and flipped the remaining spring in my lowriding days back in the 80's.
    Oct 2011
    18
    So this is what im working with
    I cant flip the leaf springs
    and there are no helper leafs to remove.
    any other ideas?
    I think I might just do lowering blocks..
    May 2009
    Melbourne Australia
    278
    Go to a spring works, and have the springs reset.
    Have a talk to them about what you want, you will likely be amazed at what they can do.
    Oct 2011
    18
    Quote Originally Posted by parrot
    I think I will try that. thanks.
    Oct 2009
    westminster
    31
    dont use blocks. Once you put on lower profile tires the perch that holds the leaf will be sooo close to the ground.
  1. Ae86 lowering springs fit ae72?
    By zakte72 in forum Resto Tips, Wheels & Other Goodies
    Last Post: 01-14-2014, 10:59 PM
  2. FS - RX2/616 King lowering springs and KYB shocks
    By JoeFerg in forum Mazda Swap Meet
    Last Post: 04-06-2012, 04:24 AM
  3. getting rid of leaf springs.
    Last Post: 03-23-2011, 06:35 AM
  4. lowering springs ??
    By AhhVtec in forum Honda Garage
    Last Post: 06-01-2010, 11:32 PM
  5. identify lowering springs
    By hotdoghogie in forum Toyota Garage
    Last Post: 08-04-2009, 12:39 AM
