Results 1 to 3 of 3
Thread: need info fast
    need info fast
    hi everyone,
    I'm currently rebuilding my L20s (six cylinder) from my c31 laurel 1983-84 model
    I really need the torque specs for the hex head bolts and the crank caps bolts
    help is really appreciated
    the head bolts are black and stamped with number 13 on top :?
    I already torqued them in sequence 1) 20 2)40
    but I feel like 40 is too low since I had to use a steel bar to crack them loose the first time!!
    May 2009
    Elbow deep in grease, in a garage somewhere in Sydney
    Re: need info fast
    I can remember my book for the 260Z quoted between 33 and 40 for the main bearing caps and the conrod big-ends. I too thought it was a bit low but its what was printed in the factory service manual :?
    That book will also have head bolt specs but its at home and I'm at work :lol:
    I'm sure someone can remember them off top of their head.
    Jun 2008
    New Zealand
    Re: need info fast
    According to factory manual....
    Head bolts:
    Up to March 71 production 6.0 - 7.0kg-m (43 - 51ft-lb) straight bolt and washer
    From April 71 production 7.0 - 8.5 (51 - 61) hex bolt
    Main bearing cap:
    4.5 - 5.5kg-m (33-40ft-lb)
    Connecting rod cap nut:
    M9 size bolt 4.5-5.5kg-m (30-40ft-lb)
    M8 bolt 3.7-4.3 (27-31)
    By ghettoboy247 in forum Introduce Yourself
    Last Post: 07-29-2013, 11:11 AM
  2. Fast Eddies Racing - South Bay Meet!!
    By mommabear in forum Events, Meets & Gatherings
    Last Post: 11-17-2012, 04:49 AM
  3. Fast Fours & Rotaries Jamboree 21 & 22 August 2010 a
    By redzone in forum Events, Meets & Gatherings
    Last Post: 08-06-2010, 12:42 PM
  4. Fast idle problem
    By Long in forum Toyota Garage
    Last Post: 01-18-2010, 04:42 PM
  5. fast j-tin have no clue what it is, well kinda but not sure
    By slickwrick in forum General Discussion, JNC News & FAQ
    Last Post: 07-10-2009, 09:22 AM
