Results 1 to 10 of 15
Thread: My 71' SR20VE 510
    Nov 2010
    TX
    7
    My 71' SR20VE 510
    I have the car posted around on other forums but I never got around to posting here so I'll just post everything, including the updates, in my first post. I just had it re-tuned and it put down 220/hp and 164/tq.
    Current mods -
    Motor and go stuff
    S14 SR20DE block with SR20VE NEO VVL head (11:1)
    R&D Factory high capacity oil pan
    Custom Danstoy intake manifold, AE111 ITB’s and T3 velocity stacks
    One off DGR equal length stainless 4-1 header
    Custom DGR aluminum radiator with 12" electric fan
    RCI aluminum overflow tank
    LS7 coilpacks
    2.5" exhaust with stainless Magnaflow muffler
    S14 5spd with short shifter
    Modified S14 driveshaft
    4:38 JDM Subaru LSD
    RCI aluminum 10 gallon fuel cell with walbro pump
    Electronics
    Haltech E6X EMS
    Custom S14 wiring harness
    Greddy oil pressure, fuel pressure and water temp gauge
    Prosport 80mm tachometer
    AEM UEGO wideband
    Suspension
    MADDAT engine mount kit with 1" front swaybar
    MADDAT steering box brace
    S14 Meagan front coilovers on 280Z spindles
    Techno Toy rear coilovers
    Techno Toy RCA’s
    Techno Toy Camber plates
    Techno Toy tension control rods
    Cusco strut bar
    280Z front disk brakes
    Interior
    Recaro SRD seats with schroth harnesses
    Nardi Deep corn 350mm wheel, ACR (Japan) Steering wheel adaptor and Works Bell quick release hub
    New carpet
    Odyssey battery/bracket relocated behind passenger seat
    Fire extinguisher
    Taking delivery
    Some initial pics
    Edited pics
    First updates -
    Resprayed the door panels from the nasty original blue to black
    Scrapped and recoated the fender wells
    Low oil pan is low
    Just finished these updates last week -
    Prosport 80mm tach
    matching Greddy fuel gauge
    tripple gauge pod
    AEM UEGO wideband gauge
    orange LED bulbs to replace the stock speedo bulbs
    mounted a fire extinguisher because you never know.
    Header - welded two o2 sensor bungs, had it performance coated from Polydyn and replaced the stock gasket with an S15 7 layer gasket
    a new set of LS7 coil packs
    I had the injectors cleaned, flowed and balanced
    -8 AN lines and fittings from valve cover to the catch can
    I had the lower intake runners, velocity stacks and the catch can chromed
    I tapped the lower runners for vacuum lines and ran them to a vacuum distribution block --> to MAP sensor
    I had the valve cover and strut bar ends powdercoated a custom mix (pics do the color no justice)
    Transmission and LSD flushed and filled with Amsoil
    brakes and clutch bled and filled with ATE super blue racing fluid
    Mar 2010
    SF Bay Area, CA
    351
    Re: My 71' SR20VE 510
    Very nice!! :tu: Would love to hear the SR running...mmmm ITBs
    Dec 2009
    Netherlands
    615
    Nice, very nice, i like the car and the engine, and the combination is great!
    Apr 2010
    San Diego, California
    602
    O mai goodness. A carb'd SR20!! :shock: Super nice. I love it :tu: !! Is this how the car was delivered to you?? Looks like the car was well taken car of.
    Constructive criticism: I honestly have reserves about the battery placement though. Although, Optima makes their batteries sealed, they also recommend that it's best that it be place in a separate sealed box of it's own due to possible fumes that may escape. Just a risk I personally wouldn't take.
    Painting those interior door panels and adding the carpet was an awesome move. I hope that my 510 will eventually come out looking this nice. I still have a long way to go on my project.
    What are the wheel specs btw?
    I don't mean to drill you but that's a nicely done up 510.
    May 2009
    Elbow deep in grease, in a garage somewhere in Sydney
    160
    Quote Originally Posted by Drive510
    Not quite. Individual throttle bodies. Still fuel injected but uses the same principal as twin dual throat carbs like dcoe webers or Dellorto dhla's etc which is one lot of mixed fuel and air per cylinder.
    Best of both worlds really when you think about it.
    In saying that, I think there are some SR20's getting about with carbs, there's no reason why it cant be done :mrgreen:
    Nov 2010
    TX
    7
    Thanks guys I'm borrowing my buddies GoPro this weekend so I should have some video of it tooling around by next week.
    :tu: It came with the motor and such already but it's taken a lot it to get it where it is now. As far as the body the car is rust free aside from what surface rust you can see. She's a little rough on the panels and paint but in great condition otherwise. I actually really dig the patina roughed up original look though.
    I appreciate the battery concern, I do need to get a sealed box but I just haven't gotten around to finding one.
    The wheels are 14x7 -9 w/ 185/55/14's all around. GL with your project.
    Jun 2008
    New Zealand
    54
    can't wait to hear this thing! Make sure you do some in cabin filming with the gopro too!
    Nov 2010
    TX
    7
    Quote Originally Posted by Flauski
    Me either! I've yet to ever rev it past 5K since I didn't really trust the old tune, and I've only driven once to work since I got it back with the retune. It will be the first time I rev it to 8K and I bet that motor is going to just scream :tu: In cab filming is all I'm going to do, not my camera so I don't want to take a chance of it falling off mounted outside.
    Dec 2009
    southern PA
    278
    :shock:
    so
    perfect
    ahhhhhhhh
    Jun 2007
    Yuma, AZ
    36
    TITS!
    I love NA cars, they sound better... 8)
