Results 1 to 6 of 6
Thread: Car has been sitting since 1999..
    Oct 2011
    Pomona, Southern California
    18
    It is a 1985 Chevrolet Sprint [Suzuki Cultus]
    ran well, it was just parked and forgotten.
    all original.
    I've had it for a week now.
    I have cleaned it.
    removed a couple dents.
    replaced things like:
    oil and filter
    transmission oil
    air filter
    fuel filter
    coolant
    spark plugs and wires
    distributor cap.
    have not tried to start it since it has no battery.
    anything else I NEED to do?
    anything else I probably should do?
    any tips?
    photos and stuff here:
    http://japanesenostalgiccar.com/foru...p?f=15&t=16207
    ThankYou.
    Sep 2010
    Magna, UT
    689
    Re: Car has been sitting since 1999..
    Drain the gas tank. Maybe clean it out.
    Apr 2010
    Newark, NJ
    115
    Bleeding brake lines/changing brake fluid... It has been sitting for quite some time and it does get bad.
    May 2009
    Elbow deep in grease, in a garage somewhere in Sydney
    160
    While bleeding brakes and replacing fluid, check the wheel cylinders if it has drum brakes. The seals perish in them pretty quick.
    Also, check the tyres closely, they'll be pretty dry and hard and probably aren't much good anymore.
    Good luck :mrgreen:
    Oct 2011
    18
    SHE RUNS!!!
    Dec 2009
    Netherlands
    615
    good, no go and drive it.
  1. Long sitting '71 1800- Now runs, trying to troubleshoot...
    By Stationwagonguy in forum Mazda Garage
    Last Post: 10-26-2012, 04:31 PM
