Results 1 to 3 of 3
Thread: Spark plug question?
    Aug 2010
    perth western australia
    Just a question about spark plugs.
    The engine I have is a 12a 6 port and its had mild porting I think , the spark plug I think it should take is a BUR9EQ is this right?
    PS the eye brow is still on the plug holes.
    Stu.. :idea:
    Mar 2010
    Re: Spark plug question?
    Here's a link to NGK specs for plugs:
    Generally the BUR series plugs came standard in the turbo engines -
    13BT and 20BT, BUR7 or 8 EQ(leading) and BUR9EQ(trailing).
    In my 13B secondary bridge, I'm running B9EGV. If it was an everyday driver then I
    would probably run a slightly hotter plug - 7 or 8(leading), to stop them fouling.
    There are lots of different plugs to suit your car, from 1 to 4 electrodes.
    Take your pick.
    Aug 2010
    Thanks for that. I need a long plug because of the eye brows on top of the holes.
  1. Help please 1983 RX7 GSL no spark
    By ColoradoKP in forum Mazda Garage
    Last Post: 10-20-2013, 06:26 PM
  2. 79 Supra no spark
    By 79Supra in forum Toyota Garage
    Last Post: 04-14-2013, 05:19 AM
  3. Spark plugs for a 5M?
    By dan on a plane in forum Toyota Garage
    Last Post: 07-06-2012, 06:03 AM
  4. 4M spark plug access
    By stefman454 in forum Toyota Garage
    Last Post: 05-18-2012, 05:07 PM
  5. KGC10 L20 spark plug gap
    Last Post: 07-20-2011, 10:59 PM
