Results 1 to 7 of 7
Thread: Ford Courier engine simiar to 808 engine?
    Feb 2007
    Canada
    179
    This might be a silly idea but there is an apparently smooth running '74 Ford Courier for sale cheaply - the owner is talking about swapping a V8 into it. It has a 1.8L engine and four speed manual. My '73 808 has a 1.6L with the four speed. I believe these are the same engine family - NA? Could I get take the Courier 1.8L and bolt it into my 808 using the 808 gearbox? I'm assuming the truck gearbox might have a lower first gear or something. Would there be any gain to bolting the 1.6L head onto the 1.8L? Thanks - there doesn't seem to be much info on these engines out there. Seems everyone tosses them for a rotary.
    Feb 2009
    san jose, ca, usa
    88
    Re: Ford Courier engine simiar to 808 engine?
    At that point put a 12a in it! theres gotta be a few 1st gen rx7s still running but unloved up there.
    Guest
    I believe the 1.8 from a Courier is just a stroked 1.6. Should swap over no problem. I would think the 1.8 head may be better flow wise, but the 1.6 may have a smaller chamber that would net higher compression. I have never seen a 1.6 cylnder head, and it's been years since I've seen the 1.8, so I could not tell you with any certainty.
    Mark
    Mar 2007
    Pac NW
    501
    Its been many moons(32 YEARS)... but I could've sworn my Courier used a 2.0 Pinto engine......
    Guest
    The 2nd gen Courier used a Ford 2.3 engine in addition to the Mazda 2.0 engine. 1st Gen was 1.8 Mazda only.
    Mark
    Mar 2010
    Ballarat
    197
    I was always told if I was going to do any of the old series Mazda motors up, go the NA.
    Shorter stoke means more revs.
    From my engine manuals:
    1600 - NA Bore - 78mm(3.07 in) Stroke - 83mm(3.27 in)
    1800 - VC Bore - 80mm(3.15 in) Stroke - 88mm(3.46 in)
    2000 - MA Bore - 80mm(3.15 in) Stroke - 98mm(3.86 in)
    I've seen a few 808s with MA motors in them but with the extra height in the block
    the standard airfilter no longer fits when the bonnet is closed. They have then fitted the
    "snorkel" type airfilter assemblies from the early model HB 929 with MA motors, that
    remote mounted the airfilter towards the inner guard.
    Feb 2007
    Canada
    179
    Thanks all for the feedback. The engine and displacement sure made some things clear in my head now. Not sure what I am going to do but I do feel a bit more clear now in my understanding. Thanks again.
  1. '76 Ford Courier
    By dihsu91 in forum Mazda Garage
    Last Post: 05-11-2015, 02:34 AM
  2. 1975 Ford Courier Colorado Springs CO
    By zionfarm in forum Junkyard Finds
    Last Post: 12-08-2011, 09:49 PM
  3. WTB - L18 Engine
    Last Post: 07-21-2011, 06:14 PM
  4. WTB: L16 Engine
    By olemaeland in forum Datsun/Nissan Swap Meet
    Last Post: 06-18-2011, 01:32 AM
  5. Engine
    By Yayoi in forum Toyota Garage
    Last Post: 01-15-2010, 06:48 PM
