Results 1 to 7 of 7
Thread: AN600 Service Videos
    Mar 2011
    Monrovia CA
    100
    I am making videos of breakdown of one of my AN600s. I hope they might assist others as they tackle various aspects of restoring and maintaining their early Honda's Here are two videos. One is on removing a strut and the other on removing the shifter assembly.
    http://www.youtube.com/watch?v=fBep6ww4W68
    http://www.youtube.com/watch?v=CfHXo5EZ6iE
    Sep 2011
    Spain
    42
    Re: AN600 Service Videos
    Thanks, always useful for newbies like me :tu:
    Jan 2012
    San Jose
    7
    Nice Vids, I have a question since I see your rebuilding the motor. I have a 72 600 sedan and I am having a hard time finding the oil plug. Its not a normal plug because it looks like it has an oil pressure sensor type of rod going through it. Did you have this on your motor? I am going buggy trying to find someone to help out on figuring this out as well as looking for the part online. I am also not sure if I can just put in the normal plug because this is what all the parts places are saying that goes in their. I am starting the restoration process. Here is a picture of the item I have.
    mc
    Mar 2011
    Monrovia CA
    100
    Quote Originally Posted by 72cvcc600
    mc
    I am not sure what I am looking at. It seems that bung is in a different place then it should be. It also looks like that bung was added. Aren't those weld beads around it? Could post another pic looking directly at this tube but also showing what is next to it towards the front of the motor(or right of it). Here is what both my engines look like.
    http://i193.photobucket.com/albums/z201 ... G_0476.jpg
    Jan 2012
    San Jose
    7
    You are correct, we have all came to the conclusion that some one along the way modified it, hence the bead welding. I have to buy the lower end of the casing and remove the old one so that its back to the way it should be.
    Mar 2011
    Monrovia CA
    100
    Are you sure this sensor is not to the left (towards fire wall) of your drain plug? Your picture looks that way. If you look at the picture I linked it looks like your bung on the left flat. Also it can't be oil pressure because there is no pressure in the oil pan. I think it is oil temperature which would be great to know. A good welder with a tig could easily close that hole and rebung it.
    Jan 2012
    San Jose
    7
    Quote Originally Posted by 8803
    Its the oil plug. Its in the same place as shown in your picture. I will have to figure out what is the least expensive way to go.
  1. mountain made AN600 build
    By Mt N600 in forum Honda Garage
    Last Post: 12-26-2012, 07:08 PM
  2. an600 headlight switch
    By Tdaaj in forum Honda Garage
    Last Post: 07-02-2012, 02:25 PM
  3. WTB: 1972 Honda AN600 part..
    By Socal VIP in forum Honda Swap Meet
    Last Post: 04-27-2011, 03:49 AM
  4. WTB: 1972 Honda AN600 Gas Cap.
    Last Post: 04-25-2011, 02:02 PM
  5. GTO videos!
    By RedSunday in forum Mitsubishi Garage
    Last Post: 01-11-2011, 06:23 AM
