Results 1 to 5 of 5
Thread: Rear axle leak
    Sep 2010
    Magna, UT
    689
    Rear axle leak
    So, I have an 80 corolla with a stock rear end. The seal on the passenger side is leaking and geting on the brakes, which is causing a failed safety.
    My question is, is there an additivive or different oil I can use in the rear end to limit/stop the leak without replacing the seal? I would prefer to just milk the rear end until I do my complete overhaul of the car.
    If not, how hard is it to replace a rear axle seal?
    Aug 2011
    Colorado Springs, CO
    52
    Re: Rear axle leak
    Nope. You need to just replace the seal.
    it's a $2-$3 seal.
    May 2011
    MCKINNEY, TX
    7
    Re: Rear axle leak
    I've seen additives in parts stores that you add to any fluid and it's supposed to swell up rubber. Don't remember the name. It may make the leak worse but it's worth a shot. Replacing the seal isn't a tough job.
    Jun 2008
    Torrance CA
    277
    Re: Rear axle leak
    Honestly. c'mon. what gives? Just fix the thing. you have an oil leak. fix it right and do it right the first time. if you can do it, pay someone to do it for you. if you cant pay for it, ride the bus and get a bicycle. c'mon....
    Sep 2010
    Magna, UT
    689
    Re: Rear axle leak
    Well, I did fix it. Turned out pretty easy and the slide hammer wasn't even needed. I had never attempted something like this before so there was some fear.
    Plus, it's a project car and I didn't want to start something that would ruin all my progress that has gotten to the point of being driveable Thats what I was afraid of. Also, didn't want to spend alot of money on a part that I will replace when I blow up the motor, engine or rear end.
    Also cleaned the breather on the diff. Think that is what caused the leaky seal.
  1. RX7 GSL disc brake rear axle
    By in forum Mazda Swap Meet
    Last Post: 09-16-2014, 09:36 PM
  2. HELP!! Need U-bolts for TE61 rear axle.
    Last Post: 07-07-2014, 05:11 PM
  3. WTB Datsun 810 rear axle
    By vjones352004 in forum Datsun/Nissan Swap Meet
    Last Post: 11-26-2012, 02:18 PM
  4. AE86 GTS Rear Axle
    By RotaSpinna69 in forum Toyota Swap Meet
    Last Post: 05-01-2012, 01:27 AM
  5. WTB: Supra rear axle mki 79 - 81
    By njccmd2002 in forum Toyota Swap Meet
    Last Post: 12-20-2010, 02:47 AM
