Results 1 to 3 of 3
Thread: tranny swap question
    Jun 2009
    what mods would be necesarry to transplant a 5-speed tranny (from a boxie) to a 4g32 (chain type) from a 73 dodge colt?
    Feb 2008
    East Wallyworld Vermont USA
    The transmission crossmember needs to be moved back some.
    The two studs that bolt the mount to the transmission are spaced wider on the 5 speed. You can elongate the slots in the mount to work.
    Occasionally the shifter opening will be a bit off but is easy to deal with.
    Dec 2007
    New Zealand
    Yeah that all the issues I had, also the drive shaft cover piece on it (where it slots into the gear box) cut off.
  1. ke20 4age swap question
    By 73AgentOrange in forum Toyota Garage
    Last Post: 03-22-2015, 08:48 AM
  2. 1972 240z Transmission Swap Question
    By Lugnut in forum Datsun/Nissan Garage
    Last Post: 01-10-2013, 08:29 PM
  3. R31 Skyline body panel swap question
    By ToolZ in forum Datsun/Nissan Garage
    Last Post: 01-11-2012, 06:51 PM
  4. Wiring question for 1J swap.
    By c72c in forum Resto Tips, Wheels & Other Goodies
    Last Post: 04-08-2011, 06:19 PM
  5. auto to manual tranny swap
    By ghostking in forum Toyota Garage
    Last Post: 07-15-2010, 04:45 AM
