Results 1 to 10 of 19
Thread: Kingtoy's Suzuki GS750
    Feb 2007
    Lake Worth, TX
    677
    Well I did buy a GS300 but that needed alot of wiring work that I didn't want to tackle. So I put it up for sale and went out and bought me a new bike. Here is my (new to me) Suzuki GS750. It is all original right now but I do intend to do the "bobber" treatment to it.
    5,527
    Re: Kingtoy's Suzuki GS750
    I like it. 8)
    Feb 2007
    Lake Worth, TX
    677
    I like it. 8)
    So do I. :mrgreen: I also realized that the front tire popped it's seal and won't take air now. Also, the ignition keeps wanting to lock the tree.
    5,527
    Quote Originally Posted by kingtoy
    If you put it up on the center stand and have someone sit on the seat so the front tire is off the ground, it will pop back on the bead and air up. :tu:
    But if it lost that much air in a week or two, sounds like there's a leak that needs fixing. :x
    Feb 2007
    Lake Worth, TX
    677
    Well I have bled the rear brake. I still need to get a battery and fix the front tire.
    5,527
    FWIW, mine was pretty flat, and had sat for 2+ years. I topped off the fluid, did an overnight low-amp charge and it came back to life. Worth a shot?
    Hopefully yours has the smaller (cheaper) battery. Ebay is the best place to get the smaller ones. :wink:
    Feb 2007
    Lake Worth, TX
    677
    Well I took it to the shop and put it on Jonathan's charger. It seemed to take a charge, so if I have a minute I might try to pop it back in the bike and see if it will start.
    If it does then all I need is the front brake master cyclinder.
    5,527
    If you want to learn from my mistake, drain the gas from the tank and put fresh gas in it before you try to crank it. :wink:
    Feb 2007
    Lake Worth, TX
    677
    Well I hooked up the new battery today and gave it a go. It took a little bit, and I had to crack the throttle to start it, but it starts and runs. The idle seems off cause it won't idle on it's on when you lift off the throttle and I think the carbs are sticking some cause sometimes it hesitates before reving up.
    So now I just fix the front tire, replace the front master cylinder and maybe try to clean the carbs a bit and we should be in business.
    5,527
    Woohoo! :tu: :mrgreen:
  1. (SOLD) Kingtoy's 1982 Suzuki GS300 L "bobber"
    By kingtoy in forum Japanese Motorcycles Garage
    Last Post: 09-08-2011, 01:39 PM
  2. 1978 Suzuki GS750
    By spiff in forum Japanese Motorcycles Garage
    Last Post: 08-17-2011, 10:36 PM
  3. looking for a suzuki re5
    By derek in forum Japanese Motorcycles Garage
    Last Post: 07-21-2011, 11:06 PM
  4. Kingtoy's 81 Corolla TE72 sport coupe
    By kingtoy in forum Toyota Garage
    Last Post: 05-27-2011, 01:01 PM
  5. new suzuki guy
    By geopat in forum Introduce Yourself
    Last Post: 01-08-2010, 03:29 AM
