Results 1 to 10 of 12
Thread: 1984 Mazda RX-7 GSL-SE
    Aug 2011
    Colorado Springs, CO
    52
    I've had this car since September 2010. I have about 195k miles on the car.
    What the car looks like right now:
    http://i293.photobucket.com/albums/mm71 ... G_1255.jpg
    http://i293.photobucket.com/albums/mm71 ... G_6287.jpg
    I have a full writeup on the car restoration on my blog: http://chrischillino.com/
    Dec 2009
    Dongducheon, Korea
    330
    Re: 1984 Mazda RX-7 GSL-SE
    Sup chris nice FB man, we should meet up some time. I just came back from Afghanistan and I own a 2nd Gen RX7.
    Aug 2011
    52
    Thanks, I just PM'd you.
    Aug 2011
    52
    I made really good progress on the installs but it took longer than I planned. Old cars are a pain to work on sometimes. I finished the bearings and brakes all the way around.
    I now have new outer bearing for the rear and new inner and outer bearings for the front. I also have seals front and rear and Royal Purple oil in rear. The brake rotors are replaced both front and rear as well as new wheel studs for the front rotors. The pads and hardware are new all the way around and the front are Hawk HPS pads. Stainless steel brake lines and speed bleeders are now installed all the way around. The ball joints are replaced as well and I would say that was probably the hardest part of the project.
    I still have to replace the tie rod ends, pitman arm, and idler arm. The OMP still needs to be rebuilt as well. I plan to get this done this Friday. When I get this all done I plan to rebleed the brakes one more time.
    Jan 2011
    Canada
    51
    Very Nice! :tu:
    Aug 2011
    52
    Feb 2010
    Orlando
    213
    Looking very clean.
    Aug 2011
    52
    thanks, it is a 2 seater.
    Aug 2011
    52
    It looks like I may be getting my car finished sooner than I had originally planned. And when I say finished, I mean completely finished. I'm hoping to start hitting the car shows this year hard.
    The list of what I'll be getting done:
    -rust and dent repair, front subframe tweeked, paint.
    -new seals, emblems, decals, etc
    -wheels refinished
    -drivers seat repaired
    -carpets redyed
    -high flow cat
    -throwout bearing
    I'm hoping to have it all done by late spring.
    Aug 2011
    52
    I ordered the Bönez Performance Converter System over the weekend. I will be getting that and the throwout bearing done while the car is at the shop on the lift. I'll be doing the install myself.
    I'm going to the paint shop tonight to go over the project. He will be doing the full assessment of the car today. I plan to start ordering the seals and emblems in the next few days. I want to see what he thinks I will need first.
    I will post progress pics as soon as I have some.
  1. 1984 RX7
    By p71sohc in forum Mazda Garage
    Last Post: 07-01-2013, 01:04 PM
  2. Washington State - 1984 Series 3 Mazda RX-7
    By ioTus in forum Introduce Yourself
    Last Post: 02-24-2013, 01:45 AM
  3. 1984 Mazda RX-7 GS found on BaT
    By SevenHeaven in forum Ad / Auction Finds
    Last Post: 12-21-2011, 11:38 PM
  4. 1984 Mazda 626 Coupe TWR
    By 626coupe in forum Mazda Garage
    Last Post: 03-16-2011, 11:35 PM
  5. 1984 Mazda B2000
    By Camshaft in forum Ad / Auction Finds
    Last Post: 12-26-2010, 08:34 PM
