Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: DIY hybrid 2E-FE engine, 2E with 16V twincam and EFI: ALIVE!
    May 2011
    Netherlands
    170
    2E-FE is being built by me, my Starlet engine needs a rebuild, it sips oil, runs lean on 2 to 3k revs, and has had pollution gas test problems.
    From 2E (carbed) engine i use:
    Block, crank, rods, tranni, clutch, starter and so on
    From a 5EFE with distroyed crank bearings i use:
    16V Head, pistons (to be pressed on the 2E rods) Timing gear, Intake and exhaust manifold.
    Extra things needed: 2EE or 4EFE ecu, wiring harness, electric fuel pump and some thicker fuel line, petrol catch can in engine bay to insure fuel supply in the longer curves.
    The cilinders have to be bored to 74mm (are 73)
    At the moment busy with flowing the head. Keep you posted.
    Jul 2011
    25
    Re: 2E-FE
    :tu: nice
    May 2011
    Netherlands
    170
    Re: 2E-FE
    Thanx 8)
    3 exhaust ports flowed:
    Feb 2010
    Great White North
    144
    Re: 2E-FE
    Cool.
    Serious dedication.
    Are 5E-FE used engines available there?
    Also, the head gasket from a 1996 Tercel 5E-FE (if I remember correctly) is a .25 mm copper gasket from Toyota.
    This might be a cheap compression ratio increase for you. Just make sure you have adequate clearance between the pistons and the head.
    May 2011
    Netherlands
    170
    Re: 2E-FE
    Yes the Paseo is availablke here with 5EFE
    Nice tip, good idea, but i am offered a set of 5EFHE pistons, so the CR will be increased to 1:9.8 or so. Will use a standard 2E gasket.
    It is nice a lot of parts from the E series can be combined throug the whole line of capacity engines.
    May 2011
    Netherlands
    170
    Re: 2E-FE
    Pressed the pistons off the 5E rods lately. The 2E is dismantled, the conversion begins...
    3 hours of pulling the engine out(2 man), 2.5 hours completely dismantling (me only). Not bad for non garagists.
    2E needs some attention, a lot of carbon.
    On the right the diy press helping tools.
    May 2011
    Netherlands
    170
    Re: 2E-FE
    Block is bored/honed, balancing the 4 valve pistons with the rods, busy to combine 2 wire harneses.
    Combined 2 covers for the timing belt (2E bottom, 5E top cover) Had to saw some out the 2E one.
    Coppersheet for headgasket is ordered, techline/camcoat coating for bearings and pistons must be applied too
    Apr 2009
    Banawe Q.C. Philippines
    1
    Re: 2E-FE
    good morning sir. do you have by any chance an ecu pin out of your 2EFE engine? I'm converting my 3k engine from a kp61 to efi using the ecu of a 2EFE.Myt ecu part number is 89661-25060 which does not have markings from the inside.Thank you in advance.kudos to your work on the engine.
    May 2011
    Netherlands
    170
    Re: 2E-FE
    Hi Ngota1
    There is no existance of a 2E-FE original from Toyota! :mrgreen: You must have there a EFI setup either of a 4E-FE or 2E-E
    Pulled some schematics from the i-net and braided the extra EP81 (2E-E) wiring harness into my EP71 harness.
    Used this one in special:
    Some extra useful schematics: (from: http://www.toyotagtturbo.com/forums/sho ... g-Diagrams )
    http://street-legal-starlet.nl/Sagittarius/Wiring/SLS - EP71 Wiring diagram 2e-elu.jpg
    http://street-legal-starlet.nl/Sagittarius/Wiring/SLS - EP71 Wiring diagram 2e-telu.jpg
    Here is some info on pinout of ecu: (4EFE though, but allmost the same as 2E-E)
    Allmost done with my wiring harness
    May 2011
    Netherlands
    170
    Re: Carbed 2E and 5-EFE: LEGObuild of a hybrid 2E-FE engine
    Busy with making a 0.8mm HG from coppersheet. ACL duraglide bearicg are on their way, within 1 or 2 weeks building can start.
  1. My Honda Z 600 Rat Rod is alive!
    By 2stroketurbo in forum Honda Garage
    Last Post: 12-18-2012, 06:23 PM
  2. Still alive.
    By TheDSMguy in forum Off-Topic
    Last Post: 05-24-2011, 08:42 PM
  3. 1980s Translated Twincam brochure
    By ToyGuy in forum Toyota Garage
    Last Post: 01-20-2011, 11:09 AM
  4. Toyota Twincam II Brochure - Translated
    Last Post: 11-01-2010, 02:00 PM
  5. Replies: 0
    Last Post: 05-28-2009, 06:48 AM
