Results 1 to 10 of 13
Thread: 78 civic hatch 1200 series: carb problems
    Jul 2011
    24
    so im having carb problems with my civic. when ever i give her gas she back fires.. bought it from a co-worker and haven't done much to it. changed the sparkplugs (gaped right) changed the spark wires and cap (wires are right) had the timing done professionally. i no that the mechanic had to gap the points a bit larger then they shoulda been for some reason. noticed that the carb had no vacuum lines and everything was capped off. bought some tubes but with out a diagram i have no idea where to plug them into. also noticed that the carb has a leek in it.
    so basicaly i need a vacuum line diagram and a carb repair kit. would love a recommendation for a kit and some tips about stuff.
    anything will be appreciated =]
    heres a pic of the carb if it would help:
    http://tinypic.com/r/21ngmmg/7
    Jul 2011
    Georgia
    20
    Re: 78 civic hatch 1200 series: carb problems
    i have the same problem mines excatly the same way but it runs fine times adjusted up and one vac line hooked up..repair manual should show u how to hook it up..i got a NOS repair kit with gaskets for da carb just put one in..and my points were messed up bad...but got her runnin and got turn off now
    Mar 2011
    Monrovia CA
    100
    Back fires through the carb or exhaust are because a valve is still open during combustion. Recheck your timming and make sure a valve is not sticking.
    Switched plug wires could also result in this symptom. But a 4 cylinder would run rought as well.
    Excess gass in the exhaust could also result in an exhaust back fire. Engine would have to be hot.
    Does that carb have an anti backfire selenoid?
    Jul 2011
    24
    Quote Originally Posted by 8803
    couldn't tell you if the carb has an anit backfire selenoid, or if a valve is open. still new to this stuff so i kinda don't no what to look for.. =[
    Jul 2011
    24
    Quote Originally Posted by loa706
    could you maybe send a pick of how you have the vac line set up. right now im running three from the carb to the: adv, retard, and throttle control. so the NOS kit fit well and did the trick?
    Mar 2011
    Monrovia CA
    100
    Is this a CVCC motor?
    Jul 2011
    24
    no i don't think it is a cvcc motor.. the cars is a 1200 series witch i think is a step down from the cvcc's
    Mar 2011
    Monrovia CA
    100
    A bit more info. If it is a backfire into the exhaust there has to be air for the excess gas to explode. Again this is most likely related to timing in reference to things happening when the valves are open or a leak into the exhaust system. The most likely is again stuck valves and or a timing issue.
    Jul 2011
    24
    pretty sure its not a timing prob. had the timing belt replaced and everything tuned. (cept the carb =/) as for it backfiring, when ever i give it gas the carb 'hickups' out the top. even had flames a few times >.>
    if theres any info that might be helpfull, let me no and i'll try my best to answer
    Mar 2011
    Monrovia CA
    100
    Think of timing in a more general way. If a motor is wired and tuned perfectly a mixture of fuel and air enter the cylinder with the intake valve open, both valves close and the piston is near or at top dead center, the spark plugs arcs and ignights the gas/air mixture dirving the piston down, than the exhaust valve opens and the spent gass is released. If during the firing stroke(powder stroke) the intake valve is still open(timing) or stuck open, part of the powder is leaked back up through the carb. This is what is happening. By timing I mean something is happening out of order, which is what timing really is. A backfire through the carb occurs because an intake valve is open when it should not be. It has to be miss a adjusted intake valve, a stuck intake valve or an intake valve open when it should not be open. Have your valves adjusted. This is a part of a good tune up. Be certin the plug wires are in the right place. If you recently had a timing belt replaced I would check to see all the marks line up.
  1. Parting Out 76 & 79 Civic CVCC 3 Door Hatch Models
    By bob78cvcc in forum Honda Swap Meet
    Last Post: 08-21-2014, 08:05 PM
  2. 1986 AH Honda Civic Hatch
    By Gem wrc in forum Honda Garage
    Last Post: 06-22-2011, 08:37 PM
  3. 1989 Civic hatch
    By nzjdm in forum Honda Garage
    Last Post: 05-27-2011, 09:27 AM
  4. 610 front on a civic hatch back?
    By JKs13 in forum Datsun/Nissan Garage
    Last Post: 01-29-2011, 06:11 PM
  5. '84 B2000 carb problems
    By erose999 in forum Mazda Garage
    Last Post: 02-09-2010, 04:46 PM
