Results 1 to 6 of 6
Thread: How to lower a 1977 Mazda 929/RX4 ?
    Jul 2011
    France
    24
    Hi everybody,
    I would to have know how to lower my 929/Rx4 ?
    Can i find shorter springs for the front? Do i have to change the struts ?
    And what about the rear suspension ? Do i need specific parts ?
    See you.
    Mikis
    Jun 2011
    Geelong, Australia
    63
    Re: How to lower a 1977 Mazda 929/RX4 ?
    I'm not sure on parts availability in France.
    However you will basically need a set of lowered front springs. There are many companies worldwide that make aftermarket lowering springs to suit your car. Alternately you can have your springs reset to the appropriate height. I know in Australia you are normally better off buying aftermarket springs.
    As for the rear, you will need to have the leaf springs reset to a lower height by a suspension specialist.
    Hope this helps you.
    Jul 2011
    France
    24
    Thanks Ben,
    If i put lowered springs, can i keep the original struts or should i change them?
    Do you have brand names ? Links ?
    For the rear i found this:
    http://www.ebay.com.au/itm/MAZDA-RX4-RX ... 3cb657625d
    How does it work ?
    See you !
    Jun 2011
    Geelong, Australia
    63
    King springs make front springs to suit your application, I would recommend changing your shock absorbers to suit, however you can get away with retaining your standard ones as long as you are lowering the car within reason.
    I wouldn't recommend using lowering blocks, but as a last resort I guess they could be considered. They work by spacing the diff housing away from the leaf springs to which they are normally bolted directly to. This is the poor mans method of lowering a vehicle with leaf springs.
    Mar 2010
    denver
    35
    lowering blocks have been around since the 50's and are the simplest way to lower a leaf spring vehicle. The poor mans lowering method involves a torch and a prayer.
    Jul 2011
    France
    24
    Hi everybody,
    Thanks for the infos !
    See You !
    Mikis
  1. Mazda 323 1977 hatchs Australia SOLD to mazda dealer
    By myold323 in forum Mazda Garage
    Last Post: 10-04-2014, 09:02 AM
  2. WTB for mazda 616 / rx-2 1977
    By robin168 in forum Mazda Swap Meet
    Last Post: 09-16-2012, 04:48 AM
  3. Mazda 121/rx5 1977
    By Chuxa in forum Mazda Garage
    Last Post: 05-05-2012, 11:19 PM
  4. my mazda 323 1977
    By kieran811 in forum Mazda Garage
    Last Post: 06-14-2011, 08:05 PM
  5. Mazda 808 1977
    By in forum Mazda Garage
    Last Post: 07-10-2009, 10:30 PM
