Results 1 to 4 of 4
Thread: suspension question from a noob.
    Jun 2009
    Lynnwood, Washington
    I am new to this classic cars.
    Was wondering if the suspension pieces of these cars are interchangeable with the later model ones.
    I found a 1978 Corona sedan in the local craigslist and want to know if there are options as far as the suspension goes.
    Oct 2008
    Forty-Fort, PA
    Well..That depends on where you want to go... Pretty sure some -86 stuff works as well as toyota truck stuff..
    -Leafs in the back and the rear should be 6.7 Pretty common so easy to build..
    -Shocks are tough,good luck finding any better than KYB or Rancho
    -Sway-bars only came on the wagon(i think)But easy to fit your own,or buy one from Afco like me.
    -Front suspension is pretty much toyota truck,no struts..Easily lowered with a coil or so cut.
    -And sways in the front can be had from Afco as well..
    Check my cardomain..Working on a build list there for mine.
    Jun 2009
    the strut setup is the same design as a celica, supra, carolla from 78-85ish. they are all the same base parts, just different dimensions.
    you can mix n match some parts to get a stiffer front end, or just to have more options for aftermarket parts and better brakes.
    there is a guy who goes by A2ndopinion @ with a thread titled "wagon improvements"
    i forget just what he swapped but its listed in the thread, unfortunatly the site is down right now, but i promise it will be back up in a day or so.
    course this is assuming that you do have struts, 78 was a switch over year. so you either have struts or a pickup dual A arm setup. and there isnt crap for the A arm setup. one of these days im going to see if a newer truck A arm setup will bolt on so we could use drop spindles for a 85 pickup.
    Jun 2009
    Thanks for the reply, im gonna check the car out this week. :tu:
  1. Noob Question: Toyota 2TC vs 2TG
    By jkwade in forum Toyota Garage
    Last Post: 07-23-2012, 09:30 AM
  2. 22r-e into AE86. noob question
    By errolae92 in forum Toyota Garage
    Last Post: 06-15-2012, 04:32 PM
  3. Noob Question - Vehicle ID help
    By Drive510 in forum Off-Topic
    Last Post: 02-11-2012, 08:35 AM
  4. Suspension Question
    By The Names Yota, Toyota in forum Toyota Garage
    Last Post: 08-22-2011, 11:02 PM
  5. noob suspension discussion
    By shane_lxi in forum Japanese Motorcycles Garage
    Last Post: 07-16-2011, 01:43 AM
